1968 Mustang Seat Belts - Mustang Evolution
Old 06-06-2011, 02:58 PM   #1
I just had these 3 point seat belts installed! They worked out great!
I bought the reproduction set (the installation instructions are crap and try to have you hack at your car)
Then we modified them to make them like the stock 3 point seat belts
The upper shoulder connect that goes to the roof should be a fixed point (had to modify)
And the female connector should be a very short fixed point (had to modify)
Next the retractor and male connector were mounted to the door side floor
There were no holes drilled in the car for this, I used only the stock seat belt holes
It's so much better and cleaner than the repo-instructions
I just wanted to show it off!
ID:	27554   Click image for larger version
gdoyle05 is offline   Reply With Quote
Old 06-06-2011, 03:14 PM   #2
Re: 1968 Mustang Seat Belts
looks good, does it bother you going around your neck? looks like it might
Old 06-06-2011, 03:19 PM   #3
Not at all, it actually passes over the shoulder perfectly
my only mistake was shortening the passenger side belt a little too much, it buckles, but you can't move the seat all the way forward. I should have given it more slack. The drivers side is fine
Old 06-06-2011, 03:20 PM   #4
nice, my passenger side has no little hanger (got to put it back on) so its annoying but my drivers side is ok through its hoop.
Old 06-06-2011, 03:22 PM   #5
What little hanger? Are you talking about the roof attachment for the seat belt?
Old 06-06-2011, 03:24 PM   #6
well in my case the little hoop on the seat~ mine is a convertible so the place where it goes back into the body is down a bit from the seat back
Old 06-06-2011, 03:27 PM   #7
Ohh okay got ya, yeah I kept putting these off too, it's better to fix it than be sorry when it's too late I figured.
Hopefully no big people will want to cruise around with me, if so they'll be in the back where the belts have plenty of slack
1968 mustang
1968 mustang gt 390 value drewzx3 Classic Mustangs 6 03-09-2010 06:56 PM
july 1964 seat belts bgreen Classic Mustangs 1 09-24-2008 07:00 AM
5.0 Engine for 1968 Mustang 1968mustang Classic Mustangs 3 10-08-2006 09:55 AM
Stock Seat Belts! fastmustangs1 Mustang Audio & Video 15 04-18-2005 03:28 PM
12:17 PM
