1st classic need help plz - Mustang Evolution
Old 08-03-2011, 10:02 PM   #1
Nate98stang's Avatar
1967 original 289 with 3 speed in the floor 91k miles I want to add power steering power brakes, and there is A LOT of play in the wheel I wanna fix that as much as posible. So if anyone has any advice or anything on how to get all that done and possibly know cheap parts I'd really appreciate it have a tight budget of 200 a month or so to spend on it
ID:	29848   Click image for larger version
ID:	29850   Click image for larger version
ID:	29852   Click image for larger version
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 08-04-2011, 12:41 PM   #2
mike Franklin's Avatar
I would fix the tie rods to stop play and leave it alone. Just sayin'.
mike Franklin is offline   Reply With Quote
Old 08-04-2011, 05:43 PM   #3
Well brakes pull bad to the right as well so tie rod ends and brakes should fix my issues right?
Old 08-04-2011, 07:27 PM   #4
I don't know but it wouldn't hurt.
Old 08-05-2011, 02:38 PM   #5
Ball joints, idler arm bushing, and check to see if the control arm bushings arm shot. that should fix your play. New lower arms costs 45 a piece I believe. You'll have to replace them if the lower ball joints are bad and if the bushing around the mounting bolt is gone. They come with new ball joints and bushing already. New upper ball joints are 25 a piece I believe and make sure your get the ones with the grease fitting. Idler arm bushing is about 10. As for tie rod ends I can't remember of the top of my head but they aren't bad if I remember correctly. You can the arms at autozone I believe and the upper ball joints and idler arm bushing and napa and maybe autozone. As for power steering do you plan on doing serpentine or rack or anything special eventually? If so just save up and don't waste the money
---------- Post added at 03:38 PM ---------- Previous post was at 03:38 PM ----------
Ooo labor is what kills so if you can do it yourself your better off
Dmay65 is offline   Reply With Quote
Old 08-05-2011, 05:09 PM   #6
Great info thanks so much if I can get the play out all I want to do is power brakes instead of steering
Old 08-06-2011, 06:30 AM   #7
Do you have disks?
Old 08-06-2011, 10:26 AM   #8
Originally Posted by Dmay65
Do you have disks?
I don't have anything to switch it all over yet now it's still drums all the way around
Old 08-06-2011, 02:20 PM   #9
Are you going to buy new or used? Are you going to do front and rear?
Old 08-06-2011, 05:39 PM   #10
I'd like new and front and rear is probaly the best idea
Old 08-06-2011, 05:51 PM   #11
You can o with Granada up front and save some money, other wise just save up
Old 08-06-2011, 06:47 PM   #12
Where can I get granda brakes at?
Old 08-06-2011, 06:49 PM   #13
76-79 Granada or Lincoln versaille, check on craigslist
Old 08-06-2011, 08:18 PM   #14
Appreciate it man
Old 08-06-2011, 08:20 PM   #15
If you find one with disk brakes check out the rear end too it's a 9" and sometimes they came with disks too
Old 08-06-2011, 08:47 PM   #16
Do I have to swap the whole front end and whole rear?
Old 08-06-2011, 09:46 PM   #17
If you want the rear axle you will have to swap them and on the front it's bolt on. Swap spindles and the disk setup
Old 08-06-2011, 09:56 PM   #18
If you can get a Grenada set that's your best bet, get calipers, rotors and brake booster, get the brake pedal and mount to accommodate the higher brake pedal.
Dexter is offline   Reply With Quote
Old 08-06-2011, 10:16 PM   #19
Thanks guys really appreciate all the info
Sat. Oct. 1st All Ford & Mustang Show!! 4DRACN Regional Mustang Discussion 2 08-22-2011 02:36 PM
Alabama Events for 2011 SpectorV Regional Mustang Discussion 5 07-25-2011 08:27 AM
Sat. Oct. 1st Mustang Show in Athens, AL 4DRACN Regional Mustang Discussion 0 07-09-2011 06:14 PM
07:53 PM
