control valve problem - Mustang Evolution
Old 09-15-2007, 11:13 PM   #1
i have a 1970 mustang and have replaced all the front suspension parts but the control valve and power steering ram. well after doing the tie rods, inner and outer, along with the idler arm, i took it to the alignment shop and while checking it out they noticed a lot of movement in the control valve pivot ball. they moved the wheels back and forth and it did have a lot of play, i then took it home and had the wife move the steering wheel back and forth and i could see, what looks like, a lot of play on the pivot ball inside the control valve. i bought a rebuilt one and after separating the old one from the pitman arm i checked the free play, in the pivot ball, but really cant feel any, at least it feels like the rebuilt one. should there be a certain amount of play in the unit when hooked to the pitman arm and the engine not running.
hotrod351 is offline   Reply With Quote
Old 09-16-2007, 06:22 PM   #2
Re: control valve problem
i had same prob. with my cougar. put a rebuilt one on. prob fixed, there is no play if things are the way they should be---------------cougarman69
cougarman69 is offline   Reply With Quote
valve seals cms Pre-2005 V6 Mustang 2 08-21-2009 02:06 PM
EGR VALVE Eeyore General Mustang Discussion 14 04-16-2009 08:51 AM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 02:57 PM
valve train problem bigboy35 Classic Mustangs 1 10-23-2006 04:20 PM
09:41 PM
