License plate light question - Mustang Evolution
Old 08-07-2011, 10:52 AM   #1
Jareds65's Avatar
I have tried two different assemblies and neither worked. Both taillights work, how can I tell if the wire that you connect to the license plate light assembly is working?
Jareds65 is offline   Reply With Quote
Old 08-07-2011, 12:49 PM   #2
Use a test light on it to see if it's getting juice or if you have bad connection. Do you have a good ground
Dmay65 is offline   Reply With Quote
Old 08-13-2011, 10:44 AM   #3
Jareds65's Avatar
Ok I got a light tester and the wire works but the assembly won't, brand new assembly and bulb.
Old 08-15-2011, 01:52 PM   #4
70 Mach 1's Avatar
Check ground, more then not you will find that is the problem.
70 Mach 1 is offline   Reply With Quote
Old 08-19-2011, 05:47 AM   #5
Jareds65's Avatar
It was a faulty assembly, I got a new one and it works fine! Thanks everyone for the help, stay tuned I will have more questions!
'88 GT check engine light? robert81717 1979-1995 Mustang GT 7 07-12-2011 11:56 PM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 09:30 AM
09:22 PM
