Quarter panel welding?? - Mustang Evolution
Old 08-21-2011, 07:32 PM   #1
Ok my rear quarter panels are rusted out, can I weld the new one in and grind the welds and sand it smooth then paint? I don't wanna use bondo?
1faststang is offline   Reply With Quote
Old 08-23-2011, 02:13 PM   #2
Anybody????
Old 08-23-2011, 05:12 PM   #3
I've heard if people using some sort of lead-filler? It's really hard not to use bondo when doing most bodywork
DrSalt22 is offline   Reply With Quote
Old 08-23-2011, 05:12 PM   #4
Depends on how good the welding is? What will you be using? Chances are it will warp a little. Do you do body work?
Dmay65 is offline   Reply With Quote
Old 08-24-2011, 08:20 AM   #5
I know how to weld don't know how to do body work
Old 08-24-2011, 08:56 AM   #6
What type of welding do you do? Will you use a tig or mig? And are you used to welding thinner gauge steel? Chances are you will use bondo or "all metal" there is nothing wrong with that either. Unless you plan on taking it to a shop that specializes in metal work and want to pay a fortune there will be bondo. why don't you want to use it?
Old 08-29-2011, 06:09 PM   #7
If you are sectioning the lower parts of the quarters you will need to mig weld the seam together grind the weld smooth and use some filler to get it flat. Be careful not to apply to much heat when welding or grinding so you don't warp the panel. If you need more help feel free to ask
Mustangsandiron is offline   Reply With Quote
Rear Quarter panel repair?? 1faststang Classic Mustangs 5 08-29-2011 06:32 PM
Rear blackout panel Murph Mustang Parts for Sale and Wanted 5 08-21-2011 06:46 PM
96 coupe how to remove kick panel and sill plate Spiney 1996-2004 Mustang GT 3 08-13-2011 09:31 AM
Door Panel issue fluffyGT06 General Mustang Discussion 11 07-28-2011 12:36 PM
Blackout panel arrived! CandyRedStang10 2005-2010 V6 Mustang 7 07-27-2011 03:27 PM
02:37 AM
