65 no gas - Mustang Evolution
Old 09-25-2011, 06:12 PM   #1
65 no gas
Hi everbody just wondering my mustang with 302 v8 the gas isnt getting to the carb no Kingston in the fuel line the fuel pump mechanical pump just replaced ant ideas
Junior65 is offline   Reply With Quote
Old 09-25-2011, 06:58 PM   #2
Re: 65 no gas
Never saw a "Kingston" in a fuel line. Sorry....I know it was probably the auto correct.
Ok now to get serious.
If there are no kinks or leaks in the fuel line from the tank to the pump, my guess would be that the fuel "sock" on the end of the fuel line in the tank has collapsed and is cutting off the fuel flow.
That or the tank is really dirty and the sock is plugged up with debris.
Old 09-26-2011, 01:17 PM   #3
^^^^^ very likely. Just unplug the hose connecting to the tank sending unit and crank it and see if it squirts out any fuel. If not pull the sending unit
Dmay65 is offline   Reply With Quote
Old 09-26-2011, 07:57 PM   #4
Thanks why did i think of that
Old 09-27-2011, 10:23 PM   #5
Otlaw80's Avatar
Re: 65 no gas
Something isn't making sense about this. Maybe I'm just tired. Doesn't a mechanical fuel pump PULL fuel from the tank and into the engine. So if you disconnect the line anywhere before the pump, nothing will come out of the tank when you crank anyway??
Old 09-27-2011, 10:25 PM   #6
True but if you have enough gas in the tank it should force it out. I'm so partial to my electric pump mounted on the tank on my 65s
Old 10-08-2011, 06:25 PM   #7
nightmare_64's Avatar
Had the same prob. Dropped the tank and pulled the sending unit. Was covered in rust and crud. The gas these days do a job on steel. Replaced everything. Including both filters. Starts and runs great now.
nightmare_64 is offline   Reply With Quote
Old 10-09-2011, 05:13 PM   #8
Trying to find time to take out the sending unit thanks for all the help
97 GT Smelling gas fumes in car Sharky97 1996-2004 Mustang GT 2 09-20-2011 02:54 PM
3rd gas tank hole is what? shustwit Pre-2005 V6 Mustang 0 08-10-2011 04:51 PM
Gas 5.0 mikeny333 1979-1995 Mustang GT 7 07-30-2011 12:38 AM
Gas mickeyp49 General Mustang Discussion 19 07-23-2011 03:32 PM
not getting gas? shustwit Pre-2005 V6 Mustang 4 07-18-2011 11:17 PM
04:08 AM
