68 mustang no start - Mustang Evolution
Old 10-10-2011, 10:47 AM   #1
68 mustang no start
I bought a 68 mustang it had no engine, I put in a 90 351w, replaced the coil,distributor,plugs and wires, and voltage regulator, the problem is that the car turns over and almost starts but won't. I've checked the timing over and over again and that's all good, and it is getting spark and fuel, if someone can help me please do. Thanks.
Dexter is offline   Reply With Quote
Old 10-10-2011, 10:54 AM   #2
What type of carb are you running? Have you adjusted the air/fuel mixture? Checked for vaccum leaks around the carb?
Dmay65 is offline   Reply With Quote
Old 10-10-2011, 10:59 AM   #3
It's an Edelbrock 650 vac secondary electric choke, I did an adjustment on the air/fuel mixture, and as far as I can tell theres no vacuum leaks, but it's hard to tell when it's not running. And the carb isn't new and it was used on a 302 not long ago
Old 10-10-2011, 11:03 AM   #4
Ok I'm guessing you tried starter fluid? Do you have all ports not in use plugged. Do you have an auto tranny? If so is the vac secondaries hooked to the distributor? Do you have points or electronic ign?
Old 10-10-2011, 11:23 AM   #5
Didn't try starter fluid, all ports are plugged, yes an auto trans it the original one for the car, vac secondary are plugged in and it points, the distributor is a rebuilt one from the parts store,
Old 10-10-2011, 11:26 AM   #6
Did you check the points if they gapped
---------- Post added at 12:26 PM ---------- Previous post was at 12:26 PM ----------
Correctly
« 65 no gas | wheels »
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
01:56 AM
