Difference between 289 and 302 - Mustang Evolution
Old 10-14-2011, 09:37 AM   #1
my65's Avatar
My wife and I bought a 65 coupe a couple days ago. The place where we bought said it had a 302 in it. Other than looking on the block for the code is there an easy way to see if it is a 302 or maybe if it's a 289? Any help would be great.
my65 is offline   Reply With Quote
Old 10-14-2011, 09:59 AM   #2
93slowstang's Avatar
The blocks are the same between the two. Here's a link that will help you some I hope.
http://www.classicmustang.com/casting_numbers.htm
Old 10-14-2011, 10:09 AM   #3
my65's Avatar
Thanks for your help
Old 10-14-2011, 10:14 AM   #4
Np, happy to help.
Old 10-14-2011, 10:26 AM   #5
stampde's Avatar
Re: Difference between 289 and 302
pull a valve cover off , there's usually 289 / 302 cast into the rocker arm area of the cyl head , or get the casting numbers off of them and run them
being a 65 I'd say 289 / they didn't start putting 302's in them till late 68
2011 GT Auto
Old 10-14-2011, 10:43 AM   #6
my65's Avatar
Thanks. I know this is not the original motor. The vin shows to have an I6 installed.
Old 10-14-2011, 11:08 AM   #7
The head doesnt really tell you if the block is a 289, only the head.
Old 10-14-2011, 11:58 AM   #8
stampde's Avatar
true , but i'd put good money on it being an '89 if it has the heads
---------- Post added at 11:58 AM ---------- Previous post was at 11:56 AM ----------
but I use to put 289 heads on the 5.0 roller blocks for a compression bump ,back in the day
2011 GT Auto
Old 10-14-2011, 03:25 PM   #9
That's what I was getting at
Old 10-14-2011, 05:13 PM   #10
my65's Avatar
Old 10-14-2011, 05:33 PM   #11
A good sign is that the 302 harmonic balancer is a lot thicker than a 289.
Dmay65 is offline   Reply With Quote
Old 10-16-2011, 05:50 PM   #12
mike Franklin's Avatar
Doesn't a 302 have the smaller spark plugs?
mike Franklin is offline   Reply With Quote
Old 10-16-2011, 08:47 PM   #13
No they are the same size I believe. Newer ones I'm sure have changed
07:47 AM
