1965 Mustang 200ci drive shaft and axle - Mustang Evolution
Old 10-19-2011, 07:00 PM   #1
I have a 1965 mustang 200ci 6 cylinder and I am going to upgrade the rear axle and the whole car to five lug. First question is should I use an 8 inch or a 9 inch rear axle. Second question is if I change the rear axle do I need to change the driveshaft. Thanks
This car may later be upgraded to a 289 but the plans for now are to keep the 200ci 6. Thanks
Tuch65 is offline   Reply With Quote
Old 10-20-2011, 03:05 AM   #2
Re: 1965 Mustang 200ci drive shaft and axle
Just use an 8.8 out of a newer Fox Body Mustang along with some 5 bolt axles.
Yes, you will probably need to change the driveshaft.
Old 10-20-2011, 09:06 AM   #3
Will that handle the v8 power if at some point I do decide to do an engine swap?
Old 10-20-2011, 11:13 AM   #4
Yes, the 8.8 was first used in the Mustangs from 79-95 and it continues to be used in Mustangs today. There are some pretty powerful V8 Mustangs using the 8.8, so you won't have any problems with it behind your V8.
Old 11-05-2011, 01:48 AM   #5
Tyoung68's Avatar
I have a 68 with a 200 I put a 8" in and I didn't have to get my drive shaft re-tubed
Old 11-05-2011, 09:39 AM   #6
Did you upgrade the motor or kept the 200?
---------- Post added at 09:39 AM ---------- Previous post was at 09:34 AM ----------
Also did u have a manual trans or automatic trans?
Old 11-06-2011, 11:39 AM   #7
Tyoung68's Avatar
I haven't upgraded the motor yet I left it with the 200 and it's an automatic
1965 mustang
10:59 AM
