Electrical issue - Mustang Evolution
Old 11-19-2011, 05:35 PM   #1
Seattle66's Avatar
Electrical issue
Have stock 66 Mustang with original fuse panel. Once in a while my radio,heater, turn signals will quit working. The lights still work and no bad fuses. If I shut off the engine and restart they come back on. Any ideas?
Seattle66 is offline   Reply With Quote
Old 11-19-2011, 08:04 PM   #2
Jkgravy's Avatar
You should look into re-wiring just for the reliability factor. But sounds like could be the fuse panel itself
Jkgravy is offline   Reply With Quote
Old 11-22-2011, 11:32 AM   #3
Re: Electrical issue
Sounds like you are losing power from the ignition switch.
Try to find a diagram that shows the ignition switch wiring and trace the wire that energizes the fuse box.
Old 11-22-2011, 06:31 PM   #4
Seattle66's Avatar
Thanks that is something I will check.
Old 11-30-2011, 10:52 AM   #5
mike Franklin's Avatar
I agree with the ignition switch.
mike Franklin is offline   Reply With Quote
Old 01-01-2012, 11:34 PM   #6
TBailey538's Avatar
Voltage regulator?
TBailey538 is offline   Reply With Quote
Old 01-12-2012, 09:21 PM   #7
irishn8's Avatar
Originally Posted by TBailey538
Voltage regulator?
If it was then it would effect the lights too
Old 01-13-2012, 08:56 PM   #8
Send a message via AIM to DAndersen0605
I have a 66 as well.... did some of the same stuff.... clean the fuse box tabs...with a dremel tool..
DAndersen0605 is offline   Reply With Quote
Old 01-31-2012, 10:36 PM   #9
Diemick's Avatar
Sounds like a bad connection somewhere ! I would look for burnt connectors on the ign switch
Diemick is offline   Reply With Quote
Old 02-08-2012, 08:38 PM   #10
theStangMan's Avatar
I'd replace the ignition switch if it appear's to be the original just to be on the safe side.I have a Video that show's how to replace the switch on my website Classic Ford Mustang Restoration - Classic Mustang Restoration Videos (Powered by ClipBucket) The Doc
Chris "the Doc" Ingrassia
Mustang Restoration, Inc. - Shop Owner
www.OperationMustang.com Free Web Show - Host
www.facebook.com/OperationMustang - LIKE the Show
www.Youtube.com/CutUpMan2 - Free How-To Videos
MustangRestoration@Hotmail.com
theStangMan is offline   Reply With Quote
Old 02-24-2012, 11:12 AM   #11
LightEmUp2011's Avatar
maybe some loose or corroded connections somewhere
LightEmUp2011 is offline   Reply With Quote
mustang drivability issue wss003 1979-1995 Mustang GT 2 11-02-2011 08:14 PM
ebay headlamps leaking - common issue? solution? paradigm 1996-2004 Mustang GT 3 10-09-2011 11:07 AM
gauge issue mrc 1996-2004 Mustang GT 3 09-13-2011 08:14 AM
Transmission issue goherd 2005-2010 V6 Mustang 2 07-22-2011 06:18 PM
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 09:06 PM
01:20 PM
