Wiring a 1-wire alternator after swapping out a generator???? - Mustang Evolution
Old 10-24-2007, 08:07 AM   #1
Question Wiring a 1-wire alternator after swapping out a generator????
Ok I got my alternator mounted this weekend and need somebody who has the experience of hooking up a 1-wire alternator. There is a red bolt on the back which is what they may call the (1-wire) but there is a plug coming out of the bottom and i bought a clip to go into that and it has 2 wires coming off of it. Im not sure how to go about hooking all these wires up and which ones i really need because I had a generator on the car and it had a wire for "field" and a wire for "battery". I dont know if i need to ignore those wires and just hook up the red postive bolt to the positive on my solenoid. Any help would be much appreciated! Thanks,Donald
donaldva is offline   Reply With Quote
Old 10-25-2007, 09:29 PM   #2
Region: New Mexico
Re: Wiring a 1-wire alternator after swapping out a generator????
check your other thread
Drnaline is offline   Reply With Quote
Old 03-01-2008, 07:15 PM   #3
Region: Iowa
What year did mustangs start using alternators????
mojocat27 is offline   Reply With Quote
Old 03-01-2008, 08:57 PM   #4
fast64's Avatar
I think most of the 64 1/2's and possibly some early 65's used a generator, but everything else had an alternator.
GO BRAVES
Old 04-22-2008, 04:37 AM   #5
stang_gang's Avatar
you dont have to use the plug . hook a wire up to the alt (where the bolt is) and run it back to the hot side of the battery or the left side of the selinoid. (cant spell it) thats how i did mie and it works great
Mustangs are not anobsession they are a way of LIFE!!!
stang_gang is offline   Reply With Quote
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
fox body alternator to classic mustang wiring harness ericgreen29 Classic Mustangs 0 07-18-2009 07:35 PM
65 mustang generator to alternator conversion question?? donaldva Classic Mustangs 9 10-25-2007 09:27 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
11:45 PM
