What paint to use for the firewall and interior fenders? - Mustang Evolution
Old 12-10-2011, 07:54 AM   #1
What kind of paint do I use for the interior fenders and firewall of my 66 Mustang?
Edm_mikey is offline   Reply With Quote
Old 01-01-2012, 11:31 PM   #2
TBailey538's Avatar
Im actually in the same process of stripping and painting mine. I was just thinking some normal spray paint. Or maybe interior or high temp paint. Not to shure. Lemme know what you use and how it turns out?
TBailey538 is offline   Reply With Quote
Old 01-02-2012, 04:44 AM   #3
fordfan100's Avatar
I would use high heat most of your standard spray paints do not do well under the temperatures created by the engine
fordfan100 is offline   Reply With Quote
Old 02-06-2012, 06:06 PM   #4
Re: What paint to use for the firewall and interior fenders?
Any krylon or rust oleum spray will work, I have worked with both paint companies and heat is not an issue. Clean surface is a must. Otherwise both work great. You can also use them on the engine, high heat paint is for exhaust area. Paint will peel on an engine if it over heats, but most run less then 295 degrees and the paint will hold up to almost 350 on an engine. even high heat will peel if the engine over heats.
Scottymac is offline   Reply With Quote
Old 02-07-2012, 03:13 PM   #5
Tyoung68's Avatar
Use an oil resistant paint
Old 02-07-2012, 03:16 PM   #6
Tyoung68's Avatar
I used a paint called low voc hot rod black. Its made by colorhorizons custom finishes.
Old 02-08-2012, 12:21 AM   #7
etc1006's Avatar
I've used Krylon in the past also with great results.
etc1006 is offline   Reply With Quote
Old 02-08-2012, 01:16 AM   #8
deadsp0t's Avatar
A lot of people are filling in the holes and finishing just like the outside of the car with actual car paint.. Looks super clean.
That's unimpressive
Old 02-08-2012, 08:33 PM   #9
theStangMan's Avatar
You can use a single stage enamel like Centari by DuPont,with the use of a flatening agent to get the correct satin finish. It's thick and resistent to oil. The Doc
Chris "the Doc" Ingrassia
Mustang Restoration, Inc. - Shop Owner
www.OperationMustang.com Free Web Show - Host
www.facebook.com/OperationMustang - LIKE the Show
www.Youtube.com/CutUpMan2 - Free How-To Videos
MustangRestoration@Hotmail.com
theStangMan is offline   Reply With Quote
Old 02-24-2012, 04:18 AM   #10
jroth823's Avatar
Anyone know what paint is the best to use in my center console? I have a '66 and I'm replacing the chrome, so I want to spruce up the plastic portion of the console with a new coat of paint... Thanks!!
jroth823 is offline   Reply With Quote
Old 02-24-2012, 11:05 AM   #11
LightEmUp2011's Avatar
rustOleum protective enamel is good option.
LightEmUp2011 is offline   Reply With Quote
Old 02-24-2012, 11:28 AM   #12
jroth823's Avatar
Flat?
10:55 PM
