So guys I am having the 289 in my dad's old 66 redone and also having the c4 rebuilt at the same time. I plan to pull the engine and trans out of the car and drop them at there respective shops. I have never pulled the motor but I have done almost everything short of pulling it. So I have questions. I was thinking I could lift the car a bit, remove the radiator, then pull both at once. Is that the best way or do I need to remove the trans then pull the motor? The next and most important question; what should I replace with new parts? Keep in mind I am having the motor rebuilt to stock and same with the trans. I am probably going to go with a new starter, rebuilt carb, new bigger radiator with electric fan and an electric fuel pump. This is a running car but has problems with really low oil pressure. As for the trans, if I have the engine out I figured I may as well have it redone. The car has been a weekend toy for years. I have kept it up since my dad passed away but now it's time to bring it to LA and I want it in top running shape out here. So what would you guys recommend?
