Not 5.4 but maybe 4.6 - Mustang Evolution
Old 01-15-2012, 05:13 PM   #1
Ok so I found a 32 valve dohc 4.6 for a $100. What can I push this thing to without a blower
---------- Post added at 07:13 PM ---------- Previous post was at 07:11 PM ----------
Ps Need to know quick it might get sold fast
Dmay65 is offline   Reply With Quote
Old 01-15-2012, 05:17 PM   #2
deadsp0t's Avatar
Some came with 320hp in stock trim, some in the mid 200's don't know which cept the 99-01 Cobras were 320 I believe.
Do you know what kind of car it came from?
That's unimpressive
Old 01-15-2012, 05:21 PM   #3
It's out of a Lincoln mkviii it produced 290 stock.
Old 01-15-2012, 05:41 PM   #4
deadsp0t's Avatar
Herd some(older ones I think) had forged internals, also have been told none do. I would say they are capable of the same things as the mustang motor but heads/valves/intake could/will be different.
For $100 bucks you could buy then sell it and buy another motor. If it runs there is money to be made IMO
That's unimpressive
Old 01-15-2012, 05:45 PM   #5
99-01 were a quad cam? I thought it was 03-04. But then again I'm more into the classics. I heard you can make these things nasty
Old 01-15-2012, 11:30 PM   #6
What Is different on the cobra motor compared to the mkviii. Meaning what gives it more hp
Old 01-16-2012, 12:02 AM   #7
Dancobra75's Avatar
1996 started the 4 valve or quad cam cobras, in 03 they were treated to a cast iron block, eaton roots type supercharger and forged internals, I'd say most of the power comes from the very flow friendly heads and of corse a blower
Dancobra75 is offline   Reply With Quote
Old 01-16-2012, 01:13 AM   #8
This is a 94 block, I believe they started late 93. It's got the vaccum powered port butterflies unlike the electric ones the mustangs came with I believe. I figure I could put a cobra intake on it and a paxton style blower if I wanted. Just worried about clearance with a roots or eaton style blower. Also am lost when it comes to the brain and wiring. This motor doesn't come with anything except ign module. What would I need, it's so confusing trying to understand these compared to my simple 302 Windsor
Old 01-16-2012, 10:14 AM   #9
Bravebowhunter's Avatar
You would need a wiring harness and a engine computer. Which both those added up could be around $700 or more...
Bravebowhunter is offline   Reply With Quote
Old 01-16-2012, 10:35 AM   #10
You think that much, I was thinking a couple hundred max from the junk yard. And the cobras had a quad cam but they were all iron blocks correct, the mk viii was the only one with a full aluminum. And then the navigators had a full aluminum quad cam 5.4
Old 01-16-2012, 11:38 AM   #11
I don't know much about fords 5.4 but I do know if you buy a fuel injected complete engine with nothing but the ignition wires then you needle wiring harness or the engine which is gonna give you all your connectors for your sensors like tps, O2, maf, etc. and getting one new from a magazine or parts store is gonna be around 5-600 bucks and a computer is gonna put you down around 2-300 bucks
---------- Post added at 12:38 PM ---------- Previous post was at 12:36 PM ----------
And then you have to go take that computer to the dealership and have them program it for the engine you want it to control which is only like 70-80 bucks. And do not buy a computer from a junkyard once computers are programmed they cannot be re programmed you will be wasting your money.
Old 01-16-2012, 11:45 AM   #12
I thought the computer was flashable
Old 01-16-2012, 12:09 PM   #13
You can flash them with a chip to get performance and fuel economy but you can't flash them to teach them how to run an engine like how to idle and all the dwell times of the coils and injectors and all that it's really complicated to in all the programming to run the engine. When you take it to the dealership that's what there doing is flashing the computer but you can't take a computer from a junkyard car that already has programming on it and Change it to run a different engine in a different car.
Old 01-16-2012, 12:13 PM   #14
Hmmm okay, well if I could find a harness for a good price and buy a new comp i think it's still a good deal. I'll have the motor built up a little, swap the cams an crank and have it able to handle a procharger and I should get 400 easy
Old 01-16-2012, 12:34 PM   #15
Yeah def those are already almost pushing 300 aren't they? If your gonna supercharge it I'd go like 10-12 lbs of boost that will give you a lot of power and still be reliable for an everyday driver
Old 01-16-2012, 01:28 PM   #16
Yea I think I'm Gina o for it
Old 01-16-2012, 01:58 PM   #17
Sweet what are you putting it in?
Old 01-16-2012, 01:59 PM   #18
65 fastback eventually
Old 01-18-2012, 05:18 AM   #19
Sweet! I got a 67 coupe project myself.
Old 01-18-2012, 05:44 AM   #20
Yea it's moving along slow right now but she'll get done soon
Old 01-18-2012, 09:09 AM   #21
Haha yeah same here.
Old 01-18-2012, 09:15 AM   #22
But I'm glad I'm doing it most myself, it's worth it in the end, when I did my coupe I was happy with the outcomr
Old 01-18-2012, 01:16 PM   #23
Yeah I'm doing my project all by myself. I'm gonna be so proud when I'm done and it's the nicest mustang in Tuscaloosa!
Old 01-18-2012, 01:24 PM   #24
Yup I'm just getting impatient
Old 01-23-2012, 10:27 AM   #25
Newline's Avatar
Go with f.a.s.t. Xfi . It's really consistent and actually lends itself to more power. Definitely worth it of your planning on doing more with the car over time
Newline is offline   Reply With Quote
Old 01-27-2012, 04:59 PM   #26
Newline's Avatar
Anyone running a tune with the Mach 1? And If so who did it
Old 01-27-2012, 10:53 PM   #27
What do you mean, in a newer 99-04 bodystyle?
Old 01-28-2012, 08:26 AM   #28
Newline's Avatar
Yeah sorry wrong thread
4.6 ideas help! Hunter45 1996-2004 Mustang GT 14 01-10-2012 08:08 PM
4.6 vs police 4.6 deadhorse 1996-2004 Mustang GT 26 11-22-2011 09:23 PM
5.4 modular swap HPS intake ?? victory181 1996-2004 Mustang GT 0 10-27-2011 06:12 PM
V6 K-members same as 4.6? Otlaw80 Pre-2005 V6 Mustang 7 10-21-2011 11:27 AM
Starting my 4.6 to 5.4 prep and swap! Scarreddragon 1996-2004 Mustang GT 36 10-20-2011 10:40 PM
07:19 PM
