351 Winsor - Mustang Evolution
Old 01-24-2012, 01:18 PM   #1
66beast351's Avatar
351 Winsor
I am putting a 351 Winsor engine into my 1966 mustang coupe. The car was originally a straight 6 and I'm having trouble with the pipes, hedders, and transmission crossmember. All help would be greatly appreciated.
66beast351 is offline   Reply With Quote
Old 01-24-2012, 02:15 PM   #2
stampde's Avatar
Re: 351 Winsor
well that engine never came in that year and i think the engine compartment is a tad smaller than 69-70 , hooker probably makes headers ,but I'm thinking your going to have to go to a shop to get the rest made ...........
2011 GT Auto
Old 01-24-2012, 04:21 PM   #3
Newline's Avatar
They make a swap header kit.http://www.cjponyparts.com/product.a...paign=shopping
The rest of the exhaust is the same from the mid pipe back
Newline is offline   Reply With Quote
Old 01-24-2012, 08:52 PM   #4
66beast351's Avatar
Ok thanks but the transmission sits about an inch or 2 farther back. It's a baby c6 tranny anything for that?
Old 01-25-2012, 06:16 AM   #5
Newline's Avatar
May I ask why your going with the c6. They aren't really all that they are cracked up to be.
Old 01-25-2012, 10:32 AM   #6
66beast351's Avatar
When I purchased the engine the c6 was the transmission that was attached to it. The man I got it from just said to take the transmission too because he had no use for it.
Old 01-25-2012, 10:34 AM   #7
Newline's Avatar
Sell it and go with a a o d or a c4. The c6 is way too much for a normal small block. It's just overkill
Old 01-25-2012, 10:36 AM   #8
66beast351's Avatar
Hmm well could I just use the c4 off of my straight 6 even though it's a 3 speed?
Old 01-25-2012, 10:57 AM   #9
Newline's Avatar
The c6 is only a three speed also. What power level are you looking at with the 351
Old 01-25-2012, 11:12 AM   #10
66beast351's Avatar
Power as in horsepower?
Old 01-25-2012, 11:13 AM   #11
Newline's Avatar
Yes
Old 01-25-2012, 11:26 AM   #12
66beast351's Avatar
Like 400- 425
Old 01-25-2012, 11:28 AM   #13
Newline's Avatar
No need for a c6 at all then just get a good c4 and freshen it up and you'll have a nice trans ready to rock
Old 01-25-2012, 11:30 AM   #14
66beast351's Avatar
Would my old one fit the new engine? The engine is out of a 77 f-100 and the transmission is from my 66
Old 01-25-2012, 11:36 AM   #15
Newline's Avatar
Yeah it will I wouldn't just throw it in if your looking at 400 hp at lest rebuild it with some new parts and a shift kit. Not as expensive as a new trans and most likely on the stronger side. Shouldn't cost you too much either. Your probably lookin under 600 bucks and it should take whatever you wanna put through it
Old 01-25-2012, 11:39 AM   #16
66beast351's Avatar
Well I need to rebuild it for sure and only $600? That's not bad at all. I'm gonna look at it once I get home. Would a conversion kit be necessary or should it just bolt on?
Old 01-25-2012, 11:40 AM   #17
Newline's Avatar
Shoud just bolt it in and go
Old 01-25-2012, 11:43 AM   #18
66beast351's Avatar
Sweet man thanks a lot really appreciate it! I'll be on later to confirm if it worked or not
New to this...gt40p heads vs 351 Windsor.. Ponyboy66 1979-1995 Mustang GT 8 12-30-2011 10:24 PM
351 heads Tyoung68 Classic Mustangs 2 12-25-2011 05:33 PM
351 Robbie94gt 1979-1995 Mustang GT 10 11-23-2011 05:34 PM
351 heads Cm644rodrigues 1979-1995 Mustang GT 3 11-11-2011 04:03 PM
351 blocks 86gt 1979-1995 Mustang GT 9 08-30-2011 09:27 PM
05:30 PM
