302 or 351w? - Mustang Evolution
Old 02-26-2012, 03:56 PM   #1
my65's Avatar
302 or 351w?
I need some help. I bought an engine for my 65 mustang. The guy that sold it to me said it was a 302. When I searched the casting numbers through google it brought up a 351w. Cast number: c9oe-6015-c. I took of the valve covers and 302 is stamped on the heads? What do I have?
my65 is offline   Reply With Quote
Old 02-27-2012, 05:38 PM   #2
Mlarv5's Avatar
As far as I know the C9 means it is a 1969 motor the 302 stamping on the heads mean they were made after late 1967. Ford stopped making the 289 putting them in the Mustangs April of 1968 between late 67 early 68 the 289s had 302 parts in them then the 302 had the 289 left over parts in them until they ran out. With all that said it sounds like you have a motor with different parts then what it was made with. If you have a 65 do you have the supports that come from the firewall to the shock towers. If not you car started out as a 200 straight 6 and you will need to do some beefing up the front end. Check here to see your options http://www.mustangspecs.com/years/64-65.shtml
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 02-27-2012, 08:34 PM   #3
Re: 302 or 351w?
look at the front of the engine where the heads mount the the block. If the deck height is even with the Timing Chain/Water pump passage you have a 302. If there is 1" from the deck to the water pump/timing chain cover you have a 351w.
Norriscrew is offline   Reply With Quote
TKO 600 or manual valve body? zeltik 1979-1995 Mustang GT 34 02-28-2012 04:31 PM
Boss 302 wheels opinion Rolltide 2011-2014 Mustang GT 23 02-25-2012 10:33 PM
302 valve covers dreamstang Mustang Parts for Sale and Wanted 10 02-25-2012 01:56 PM
PCV OR NO PCV ?????????? rick978 1979-1995 Mustang GT 13 02-24-2012 11:42 AM
74 351w block Redsteel 1979-1995 Mustang GT 17 02-24-2012 09:17 AM
09:37 AM
