Supercharger? - Mustang Evolution
Old 03-17-2012, 12:18 AM   #1
Ryan_69stang's Avatar
Supercharger?
I have a 1969 mustang with a 302 and an auto, its not quite as fast as I wish it was. All stock. I've been thinking about supercharging it... Any thoughts??
Ryan_69stang is offline   Reply With Quote
Old 03-17-2012, 12:34 AM   #2
Depends on internals, it can cause a lot of stress on an unprepared motor. But if you stay in a moderate lbs area you should be good. What style supercharger? Roots or a Paxton? Im debating on doing a mod swap and blowing it
Dmay65 is offline   Reply With Quote
Old 03-17-2012, 12:44 AM   #3
deadsp0t's Avatar
^++ about 8lbs on cast/stock internals is fine if tuned correctly.. Add a girdle and tray and it will be solid! If you have forged internals or plan on them adding a tray and girdle will allow you to get some serious psi/hp..
Curious to see what style blower you want and if you are going carbed or EFI
That's unimpressive
Old 03-17-2012, 01:35 AM   #4
I'm thinking about Paxton, and def carbed. I can't decide if I should get a rebuild and call it good, or also get a good internal setup for a supercharger
Old 03-17-2012, 05:00 PM   #5
deadsp0t's Avatar
If you want to eventually build big boost/high HP id spend the extra cash on good internals. IMO even if you had to push back buying the SC.
That's unimpressive
Old 03-18-2012, 01:10 AM   #6
Thanks, if anyone else has any comments on performace upgrades I'd love to hear em. I'm up for hearing new things, 16 years old so I have a thirst for that kind of knowledge
Old 03-18-2012, 11:25 AM   #7
My mustang is my daily driver, so if I had all better internals and was ready for the supercharger, would I still be able to drive with out it installed and when I was ready to buy one, install it
Old 03-18-2012, 05:55 PM   #8
Yes
---------- Post added at 06:55 PM ---------- Previous post was at 06:54 PM ----------
Your going for better quality and reliability
Old 03-31-2012, 01:37 PM   #9
Commercial Member
matcox83's Avatar
One of the things you do when you upgrade internals, though, is lower the compression to help the engine tolerate the boost. You can definitely still drive it after the internal upgrade, but if you've done it right, your power will be down due to the lower compression. Upgrading the internals will be the time consumer, so I would suggest waiting until you can do it all at once to go into the engine. There are plenty of details on the web to help with that decision.
Supercharger Decisions TheJigShow 1996-2004 Mustang GT 63 03-19-2012 06:36 PM
Electric Supercharger 08Mustang 2005-2010 V6 Mustang 16 03-18-2012 12:50 PM
Coyote supercharger GrabberBlue5.0 2011-2014 Mustang GT 13 03-15-2012 07:14 PM
Supercharger/Turbo 08Mustang 2005-2010 V6 Mustang 13 03-13-2012 06:23 PM
Supercharger/Turbocharger ramosjose16 Pre-2005 V6 Mustang 6 03-02-2012 09:37 PM
06:16 PM
