How To Use Cleco Fasteners - Mustang Evolution
Old 01-05-2008, 09:45 AM   #1
Region: Nevada
Question How To Use Cleco Fasteners
Hi Guys (Newbie Here)
I'm faburcating some panel on my '66 Convert. And I'd like to know how to use CLECO FASTENERS
Any info will be greatly appreciated. At best pics would be GREAT
I'm going to try and over-lap some sheet metal and then cut a center line in the metal to make a perfect butt joint.
And I was told to use Cleco Fasteners.
Thanks Guys
GOD BLESS
Schooner
SCHOONER is offline   Reply With Quote
Old 01-05-2008, 09:37 PM   #2
re: How To Use Cleco Fasteners
What type do you have? are they the screw type or the type you need the pliers for?
Basically you drill a hole through both sheets of metal, insert the cleco fastener and it holds them together
Reverb is offline   Reply With Quote
Old 01-06-2008, 03:16 AM   #3
Region: Nevada
Hey Guy
Thank you 4 the picture, its worth a thousand words. I think I'm starting to get it.
Thanks Again
GOD BESS
Schooner
Old 07-14-2008, 05:25 PM   #4
Region: Nevada
Question Which Celco Fasten Is Stronger
Hi Reverb ( Its me again ! ! ! )
I'm about ready to over-lap my patch panel joint.
Can you tell me which of the Cleco Fasterners are stronger in holding the sheet metal together be 4 I weld ?
Thank You
GOD BLESS
Schooner
Old 07-15-2008, 06:29 AM   #5
are you doing body repair???i never use any type of clip because it causes the metal to warp, i cut the metal to perfectly fit the hole and slip in a side and tack, then work around until the metal is fully welded flush, then i grind it all smooth and you cant tell its patched. on areas where a pinch seam is, i use 1/8" self tapping screws then after i get everything tacked, i weld the screw holes up for extra strength.
SimplyOrange is offline   Reply With Quote
Old 07-15-2008, 03:10 PM   #6
If its cosmetic welding I use these:
If its non cosmetic (floor pans etc) then i use the cleco fasteners in the pic above. You are going to need a decent fit before you put in the fasteners otherwise its not going to weld properly. If you have a gap between the two pieces of metal I drill a hole and use a nut and bolt to draw it together then tack it in place.
04:16 PM
