Front suspension - Mustang Evolution
Old 04-22-2012, 04:16 PM   #1
Front suspension
My front left tire shakes On my 64 1/2 unless I put my foot on the brake I already changed the tie rods and ball joints the caliper and berrings are good all the bolts are tights on the suspension
djv Stangin u is offline   Reply With Quote
Old 04-22-2012, 04:31 PM   #2
How old are the rims and have you always had the problem?
Dmay65 is offline   Reply With Quote
Old 04-22-2012, 04:48 PM   #3
Re: Front suspension
Everything is new I put disk brakes from a 68 cougar on it
Old 04-22-2012, 04:50 PM   #4
Ok so did you just finish the car or was it a driver and then you did the disk conversion and now you have the problem?
Old 04-22-2012, 04:57 PM   #5
I drive it everyday I'm in Houston and the roads are bad when I go over a bump it sounds like something's loose I checked all the bolts on the tie rods brakes calipers ect... The only thing I could find was the rubber bushing on the idler arm wasn't there and I could move it by hand the tie rods were tight
Old 04-22-2012, 05:14 PM   #6
Yea the idler arm can cause a reall loose feeling steering, so has it always done this?
Old 04-22-2012, 05:17 PM   #7
No just started I can fix it myself if I know whatS causing it
Old 04-22-2012, 05:22 PM   #8
I would start by replacing the idler arm budging I think they are like 12 bcos at napa. Make sure to get the right one, they have manual and power specific I believe
---------- Post added at 06:19 PM ---------- Previous post was at 06:19 PM ----------
Bushing not budging
And bucks not bco lol
---------- Post added at 06:22 PM ---------- Previous post was at 06:19 PM ----------
But other than that, have you redone the strut and control arm bushings. Go to poly if you can, but those often wear out
Old 04-22-2012, 05:22 PM   #9
Cool thanks
01:16 AM
