no headlights, tail lights or brake lights - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Classic Mustangs
Closed Thread
Old 04-22-2012, 08:15 PM   #1
68dnixcoupe is unknown around these parts
Are these tied together? fuse, harness or other. I have a 68 coupe and the head lights, tail lights and break lights don't work. Any ideas or wiring diagrams to trace down the problem? Thanks
68dnixcoupe is offline
Old 04-22-2012, 10:48 PM   #2
66MustangGT is unknown around these parts
Hey, I would check to see if you have power to all your bulbs. If not then check your fuses, then switch.
66MustangGT is offline
Old 05-01-2012, 10:22 AM   #3
matcox83's Avatar
matcox83 is unknown around these parts
Wiring diagrams are available from all the vendors. $16 maybe?? Great investment. There's a DVD version for $25 that is colorized, even better. If I wasn't at work, I could look it up, but everyone should have their own.
matcox83 is offline
Old 05-01-2012, 03:43 PM   #4
matcox83's Avatar
On a 1966, the power to the switch is a Black/Orange wire circuit 25 from the fuse panel. If you have power at the switch on that circuit (you have to confirm wire color for 68 but likely the same) the only other common point appears to be the switch.
matcox83 is offline
Old 05-01-2012, 05:49 PM   #5
Re: no headlights, tail lights or brake lights
thanks for the help went to replace the switch and was never plugged in in the first place. All lights internal and external work.
Closed Thread
11:02 PM
