Six Cylinder Performance Mods - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Classic Mustangs
Closed Thread
Old 05-08-2012, 11:02 AM   #1
matcox83's Avatar
matcox83 is unknown around these parts
Apologize if this already exists, I searched and did not find anything.
Listed are mods and notes to my 1966 200 CID 6 cylinder. Engine was named "Falcon" six by Ford back in the day. Before performing these mods, I highly recommend getting the book "the Ford Falcon 6 Cylinder Performance Handbook."
See photos in my album.
*Weber 2V on a modified late model head. Must convert to cable accelerator pedal (I used a Granada part) must make provision for kick down if automatic (I have not done yet)
*Ported and polished within limits of head design
*1.75" intake and 1.50" exhaust valves with 302 springs and one piece retainers
*Adjustable rocker arms (stock early Ford)
*CC'ed chambers for compression ratio calculation (must do when using late model head to keep compression ratio)
*Milled head
*Clifford port divider installed
*Zero decked block
*2.3L HSC flat top pistons (for compression). These come as a set of 4 so at least 2 will be mismatched. You need to static balance the rods/pistons to correct
*Otherwise standard lower end rebuild. These engines are tough stock.
*DUI distributor- basically HEI made to fit a Ford
*Classic Inlines dual out header- stainless steel with ceramic coating
*Double roller timing chain
*Clay Smith hydraulic cam 264/274 duration 110 deg lobe center
*Upgraded harmonic balancer
*2" dual exhaust from Waldron
I will comment on the performance at a later date. Not long after the build the car went to the body shop. It felt strong and sounds great.
I hope this helps anyone considering building a six. I got all parts except the port divider from Classic Inlines. www.classicinlines.com
By the way, not necessarily cheap, but by my estimation, cheaper than converting to V8 when you consider all costs to swap suspension, wheels tires, transmission, radiator, exhaust, etc. But like I said, I have to wait and see if the performance satisfies!
ID:	49622   Click image for larger version
matcox83 is offline
Old 05-08-2012, 07:05 PM   #2
buck3405's Avatar
buck3405 is unknown around these parts
Re: Six Cylinder Performance Mods
thats sharp, and is also a lot of work!
buck3405 is offline
Old 05-09-2012, 07:39 AM   #3
6t7mstg's Avatar
6t7mstg is unknown around these parts
That engine looks awesome, I'm also trying to build up an I6 200, so please keep the info coming!
6t7mstg is offline
Closed Thread
04:34 AM
