Running Hot - Mustang Evolution
Old 05-18-2012, 05:00 PM   #1
Running Hot
Hello, I have a 66 coupe with a 302 bored 40 over, I have a four core radiator,shroud,new water pump,6 blade fan, electric external fan controlled manually. if i drive on flat surfaces it seems to run fine, if i pull the grade from town to my house ( 4000' to 6500' ) it will boil over. any suggestions, Thank you in advance
ezra66 is offline   Reply With Quote
Old 05-18-2012, 06:46 PM   #2
BA68 mustang's Avatar
It could be the thermostat or someone might have installed the head gasgets backwards
BA68 mustang is offline   Reply With Quote
Old 05-19-2012, 12:45 PM   #3
Re: Running Hot
I have checked the thermostat, I guess i would need to pull the heads and check the gasket, how will i know if its on wrong, will it be obvious?
Old 05-19-2012, 08:37 PM   #4
The gasket is marked front but if you can't read it, there are holes on what should be the back part of the gasket that are not on the front... I hope this makes sense
Old 05-21-2012, 03:56 PM   #5
Commercial Member
matcox83's Avatar
Re: Running Hot
At 6500" altitude, the lower atmospheric pressure will make water boil at a lower temperature. Are you sure your system is pressurizing? You don't say if you installed a new cap of the right pressure (but I assume you did). And, did you put a 50/50 mix of coolant/water? Straight water and low system pressure at that altitude would be a problem.
Old 05-24-2012, 09:47 AM   #6
mike Franklin's Avatar
This sounds the most reasonable to me. I really can't see a headgasket problem. A good radiator cap and new coolant at the proper mix. You didn't mention if the radiator has been cleaned. Could it be partially plugged?
mike Franklin is offline   Reply With Quote
Old 05-30-2012, 06:09 PM   #7
Mlarv5's Avatar
You might also check timing and values to see if they are to tight
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
09:35 AM
