Cowl vent - Mustang Evolution
Old 06-12-2012, 07:31 AM   #1
BA68 mustang's Avatar
Cowl vent
The driver side air vent on my 68 is completely rotted out... Any tips on replacing it from the bottom without removing the upper cowl?
BA68 mustang is offline   Reply With Quote
Old 06-12-2012, 03:08 PM   #2
LeviG2010's Avatar
Unfortunately I've never heard tell of replacing it from the bottom. Most likely easier to just remove the top of the cowl and replace it. At least thats what I was told when I wanted to replace mine.
The driver doesn't pick the car. The car picks the driver.
LeviG2010 is offline   Reply With Quote
Old 06-12-2012, 07:21 PM   #3
Rats...
Old 06-14-2012, 07:56 AM   #4
Commercial Member
matcox83's Avatar
There is something called a top hat for 65-66. Looks like an Abe Lincoln hat. Goes in from the bottom. It won't compensate for major rust, but it helps with rust right around the intake. Try the online vendors.
Old 06-14-2012, 08:57 AM   #5
Commercial Member
matcox83's Avatar
CJ pony parts has them. Fits 65-68. Comes with 2 top hats and adhesive.
Old 06-14-2012, 05:46 PM   #6
Thanks... Npd makes a patch panel for like 1' over... I dont kow if it will go up from the bottom
Old 06-15-2012, 06:01 AM   #7
Commercial Member
matcox83's Avatar
Yeah, you're not going to be able to do a sheet metal repair from underneath. Here's mine. It was damaged on top so we didn't have to fix rust.
Old 06-15-2012, 03:27 PM   #8
gc19662007's Avatar
+1
I've removed everything under my dash for a rebuild and there is not really a good way to fix it from the bottom side. Luckily I don't have to fix or replace anything on my cowl or vents.
gc19662007 is offline   Reply With Quote
Old 06-16-2012, 09:26 PM   #9
Tyoung68's Avatar
Yeah there's really now way to replace it from the bottom. Same thing happen to mine except both sides
06:12 AM
