66 mustang won't start :( - Mustang Evolution
Old 06-16-2012, 12:17 PM   #1
Mustana's Avatar
I left the starter position in ACC and the next day it was dead.
Bought a new battery and worked great for a day but dead again next morning. Now I cant even jump start it. What can I do?!?
Mustana is offline   Reply With Quote
Old 06-16-2012, 07:20 PM   #2
Re: 66 mustang won't start :(
hey mustana
by aychance have you looked into ur ignition system.
u started in the right place always first, battery.
then cilioid, starer , coil, distibitor, points, egnition, Etc
smile
sillysallie is offline   Reply With Quote
Old 06-16-2012, 08:50 PM   #3
Commercial Member
matcox83's Avatar
Not trying to be rude, but it can be anything. If you have a wiring diagram and can do the diagnostics, start at the battery and check power and ground. Does your solenoid do what it is supposed to? Is the voltage right at the coil? If you can't check these yourself, you should get it to a good mechanic. Almost noone can diagnose properly without putting their hands on the car.
Old 06-16-2012, 09:51 PM   #4
mike Franklin's Avatar
I'm wondering if your battery cables are clean and tight.
mike Franklin is offline   Reply With Quote
Old 06-16-2012, 10:22 PM   #5
Tyoung68's Avatar
Or you could have tighten it down to much and break the battery case?
Old 06-18-2012, 08:34 AM   #6
Mustana's Avatar
I bought a battery charger and it's working but if that happens again, I might take it to a mechanic to see if its the alternator or other of the things you guys said. The cables are good and new battery. So hopefully wont happen again,
Thanks for your advices.
Old 06-18-2012, 02:45 PM   #7
You can put a volt meter on the battery terminals to check the alternator. Parts houses will check it but I (think) you have to take it off.
Old 06-21-2012, 05:47 AM   #8
Sainte's Avatar
No, you check the alternator by starting the car, then you remove a battery cable from the battery. If the car dies, it's your alternator. Putting a meter on the battery terminals will only give you battery voltage. Also, good voltage doesn't necessarily mean it's a good battery. You also have to check amperage, hi volts but low amps isn't too common but, it can happen.
Sainte is offline   Reply With Quote
Old 06-21-2012, 07:20 PM   #9
Mustana's Avatar
Yeah, it is the alternator I am pretty sure. The car dies after the battery lose charge.
How expensive is an alternator for this car? Is it easy to change?
I guess its the price for having old cars but I love my mustang so it worth it.
---------- Post added at 06:20 PM ---------- Previous post was at 06:11 PM ----------
Any suggestions of brands when buying the alternator?
Old 06-21-2012, 09:09 PM   #10
Sainte's Avatar
Depends on the size motors you have as far as cost. It could be anywhere from $60-200. As far as changing it, it is either 2 or 3 bolts again depending on the engine/bellhousing and the battery wire.
Just make sure you disconnect the lead from the battery before doing any work with the starter.
Old 06-22-2012, 05:39 PM   #11
Commercial Member
matcox83's Avatar
All 66's used the same type alternater. If its a driver brand is not very important. You should have several options at any parts store. They can advise. Get the best warranty you can.
Old 06-22-2012, 08:24 PM   #12
Sainte's Avatar
Hahaha Mat!
I just re-read the thread. I was thinking starters for some reason! Thanks for catching that for me!
08:51 AM
