Help - Mustang Evolution
Old 06-21-2012, 09:35 AM   #1
My_old_mustang's Avatar
Help
So I have the 3 speed automatic, and I was pulling away from my buddies house and I didn't floor it but I wasn't pulling away gently. my car felt like it ran over somthing so I looked, and nothing was there. it did this a few times. I decided to open my hood and try moving the car to see If it was in the engine and to my surprise my engine lifted 7'' out of its place and slammed by down. what should I do????
---------- Post added at 08:35 AM ---------- Previous post was at 08:31 AM ----------
But also I can't take it to the mechanic because he knows nothing he put my alternator in *** backwards and put the belt on completely wrong
My_old_mustang is offline   Reply With Quote
Old 06-21-2012, 06:24 PM   #2
gc19662007's Avatar
Motor mounts? I'm not sure if it can lift that far out but it's a starting point.
gc19662007 is offline   Reply With Quote
Old 06-21-2012, 06:45 PM   #3
Lorraine's driver
ab_mach1's Avatar
Yup, that would be my guess. I'm not sure if you can get a replacement very quickly. Hopefully the cushion or rubber mount is still there and you can just pickup a new nut and bolt that will work at your local hardware. Here is what they might look like, depending on your year.
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Instagram: @ab_mach1
Old 06-21-2012, 06:49 PM   #4
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Does sound like a motor mount. Check to see if the nut is still on the bottom in the k member or see if the bolts are still in the block holding the motor mount. If they are still there you may have a torn motor mount.
Kind of easy to change out if you have an engine hoist to hold the motor up.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-21-2012, 10:05 PM   #5
Thank you all this is my first car and that really scared the crap outa me. I really apretiate the advice
Old 06-26-2012, 02:09 PM   #6
Jknoll2013's Avatar
Replacing motor mounts is fairly easy and cheap do that and go from there
Jknoll2013 is offline   Reply With Quote
05:48 AM
