No Start 65 - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Classic Mustangs
Closed Thread
Old 06-27-2012, 04:38 PM   #1
Mechikoff65 is unknown around these parts
No Start 65
Drove the car for a few hours and parks at my house. Went down and tried to start, won't turn over. Has fuel and radiator has new coolent. Replace the voltage regulator after I noticed the battery was being drained. Took the battery In and had it charged. Waiting to see if it dies. Any thoughts?
Mechikoff65 is offline
Old 06-27-2012, 04:42 PM   #2
BA68 mustang's Avatar
BA68 mustang is unknown around these parts
Definitely something electrical... Maybe the starter solenoid?
BA68 mustang is offline
Old 06-27-2012, 05:42 PM   #3
gc19662007's Avatar
gc19662007 is unknown around these parts
Have the battery tested, not by just a volt meter, that won't give you amps. If battery is good, then have alternator checked.
gc19662007 is offline
Old 06-27-2012, 08:41 PM   #4
Also tested the alt and replaced it. Battery is good, had it checked twice. It is running smooth at the moment and I'm running it about 15 min twice a day to check if it's running smoothly. Last time it died at a stop light in town, so if it dies I want it to die at the house
Old 06-28-2012, 03:35 PM   #5
matcox83's Avatar
matcox83 is unknown around these parts
Check for corrosion on on all your terminals (battery all the way to starter and ground.). They can be intermittent
matcox83 is offline
Old 06-28-2012, 03:57 PM   #6
Filibuster
XXSTEVEO66 is unknown around these parts
Yeah if its being finiky I would assume some kind of a loose connection...I know you said you replaced the voltage regulator I might double check the connection there because that would drain your batt while it's running...just a thought.
XXSTEVEO66 is offline
Old 07-06-2012, 05:14 PM   #7
Changed out the coil wiring and made sure I had a matchbox Space on the point set. The point set was flush when I opened the cap. I think the screw is striped and loose
---------- Post added at 04:14 PM ---------- Previous post was at 04:14 PM ----------
And it's starting
Closed Thread
05:39 PM
