302 or 351 - Mustang Evolution
Old 07-12-2012, 06:31 PM   #1
Tyoung68's Avatar
302 or 351
I currently have a l6 with a c4 with a street/strip shift kit and a 8" read end if I get a 351w will my tranny and rear be able to handle it? My dad says it won't but I think it will
Old 07-12-2012, 06:38 PM   #2
Stanglover1966's Avatar
Absolutely, just be careful in near future if you start swapping out engine, the stock rear ends that came with the i6's can't handle the torque that v8's pull out. But if you already have an 8in in your stang, the 351 will do fine.
Stanglover1966 is offline   Reply With Quote
Old 07-12-2012, 06:41 PM   #3
Tyoung68's Avatar
How much can the handle? I might be a little hard on it haha you know a couple hard accelerations here and there
Old 07-12-2012, 06:51 PM   #4
If an 8in breaks after a few pulls, then something was messed TF up xD it should be fine, 8 inches are tough rear ends
Old 07-12-2012, 06:57 PM   #5
Tyoung68's Avatar
What about my transmission?
Old 07-26-2012, 01:23 PM   #6
It should be perfect I have a 351w and a c4 transmission with a 8 in rear end and its running perfectly even with a heavy foot.
pantonio93 is offline   Reply With Quote
Old 08-02-2012, 04:44 AM   #7
irishn8's Avatar
Id recomend the FMX tranni if u like auto, very durable. The c4 was for the smaller engines.
I think the c4 will b fine with the v8 but if u start adding power to that v8 u will want to beef up the c4 or put in an fmx.
Old 08-02-2012, 03:06 PM   #8
Tyoung68's Avatar
Well yeah I put a shift kit in but that's it
Old 08-04-2012, 06:38 PM   #9
Commercial Member
matcox83's Avatar
I've actually always heard the opposite, the FMX is not desirable for performance applications. C4 has had the most aftermarket attention and supposedly the best choice if built right. C4's were behind the small blocks in the 60's.
Old 08-05-2012, 02:22 AM   #10
irishn8's Avatar
I've read in multiple sourses that the FMX is very stout, its just less common. I've heard of several dragsters using the FMX. Personally id prefer a T4 though. Also the FMX is a 3 speed auto, which is less desirable than manual.
» Members Mustangs
Airika
dwood63
Amber
kensa36
Add your Mustang
10:34 PM
