Brake lights - Mustang Evolution
Old 07-15-2012, 06:12 PM   #1
Tyoung68's Avatar
Brake lights
I'm restoring my mustang and the tail lights won't go out? Does anyone have a idea why? There the only lights that are plugged in on the car and the ignition is off
---------- Post added at 12:12 AM ---------- Previous post was at 12:02 AM ----------
And it's only in when I plug my steering column
Old 07-16-2012, 09:57 PM   #2
mike Franklin's Avatar
Must be a bare wire shorting somewhere. Explain about plugging the steering column.
---------- Post added at 03:57 AM ---------- Previous post was at 03:56 AM ----------
Brake lights or tail lights? Brake light switch is on the steering column.
mike Franklin is offline   Reply With Quote
Old 07-17-2012, 07:26 AM   #3
Commercial Member
matcox83's Avatar
I'll look at my wiring diagram tonight but I think the brake light circuits go thru the turn signal switch. That explains it only happening when column is plugged in. B+ is coming from the switch but has to go thru turn switch to reach a ground. The brake switch is not the problem it only supplies power. You are likely getting an unwanted ground, probably from the turn switch or the wiring in the column.
Old 07-17-2012, 12:32 PM   #4
Tyoung68's Avatar
I looked at the wiring on the steering column and didnt see any bare wires
Old 07-18-2012, 07:08 PM   #5
Commercial Member
matcox83's Avatar
Do they come on if the brake switch is disconnected and the column is connected? Do you have a 2 wire connector at the column? I am not sure how similar it is to '66. Do you have a wiring diagram and can you use a multi Meyer? If you have the diagram trace the circuit from the switch through the column. I think the most likely culprit is the turn switch but don't spend your money until you check it.
---------- Post added at 09:08 PM ---------- Previous post was at 09:07 PM ----------
Multi meter not Meyer, that's a hot dog!
Old 07-20-2012, 01:56 AM   #6
Tyoung68's Avatar
Brake switch?
---------- Post added at 07:55 AM ---------- Previous post was at 07:53 AM ----------
I have a after market brake set up I'm using a adjustable proportioning valve from wilwood but it's not hooked up either tho well on of the wires is not attached. But the lights went out but still draining my battery
---------- Post added at 07:56 AM ---------- Previous post was at 07:55 AM ----------
And the lights only turn on when the column is plugged in
Old 07-20-2012, 06:03 AM   #7
Commercial Member
matcox83's Avatar
Yep, I understand. The brake light circuit goes thru the turn signal switch so the blinkers can override the brake lights and blink with the brake lights on. I assume you are saying your pro portioning valve has a brake light switch built in? Not familiar with that. Have seen switches in the master cylinder. Did you try disconnecting the brake switch on the pedal with the column connected? You did not say if you have a wiring diagram and a multimeter. You will only be guessing without them
Old 07-20-2012, 06:08 AM   #8
Tyoung68's Avatar
I have both not really sure how to use the muti meter
06:56 PM
