Points - Mustang Evolution
Old 07-15-2012, 10:16 PM   #1
Points
Found that my point set has the two screws and the screws go into a plater in the distributer. The holes in the plater are stripped and I can't find a replacement plater, any recommendations?
Mechikoff65 is offline   Reply With Quote
Old 07-16-2012, 09:42 AM   #2
Gil_T2's Avatar
Re: Points
Buy yourself an electronic conversion kit, or pickup an old Dis. I don,t think you find anyone to rebuild them, unless you go full restore.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 07-16-2012, 10:06 AM   #3
mike Franklin's Avatar
Or, you could retap to the next size and get new screws.
---------- Post added at 04:06 PM ---------- Previous post was at 04:04 PM ----------
If you want to go with electronic, Pertonics electronic ignition conversion is about $80.
mike Franklin is offline   Reply With Quote
Old 07-16-2012, 11:35 AM   #4
Commercial Member
matcox83's Avatar
Mike is right, just don't let any metal slivers drop in. If you get the pertronix you still have to screw it on to the plate. Duraspark is the other option. Our old engines don't support distributorless ignition (DIS). I actually bought an HEI type from Davis Unified Ignition. If you can stand that much Chevy on a Ford engine!
06:25 AM
