08-16-2012, 10:09 PM
#1 | | Registered User
| Startability
Hey I'm new to the forum and just purchased a Mach 1 that's been sitting for 36 years just wanted to know if something like this would be startable or the engine rebuilded first? I talked to the second owner who had the car for so long and he drove it in highschool back in 76 and he said he use to race it alot and had the engine rebuilt before it sat so long. So I'm wondering if a good days work on it can bring it to life looking the way it is now, thanks
__________________ |
08-16-2012, 11:14 PM
#2 | | Registered User
| Re: Startability
If it's been sitting 36 years and hasn't been started in 36 years don't mess with it. If the engine is matching numbers and you're going to restore it just start the restore, pull the engine and start breaking it down.
__________________ 2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. |
08-17-2012, 01:57 AM
#3 | | Senior Member
| Re: Startability
Sure you can give it a try.
1. Remove the spark plugs, squirt a goodly amount of oil in each cylinder, say a couple of table spoons full in each cylinder.
2. Using a socket and large ratchet or breaker bar, see if the engine will turn over. Don't roll it just yet as there is no oil on the bearings, just see if it will move.
3. Change the oil and filter, whatever is in there has to be contaminated, then remove the distributor and procure some way with a priming tool or homemade device spin the oil pump shaft counterclockwise until you have oil pressure and oil has been distributed through the engine. Re-install the distributor making sure it is in time. Once that is done roll the engine over by hand a couple of times.
4. Follow up with checking the fuel system, carb, gas tank etc. and replace the plugs, connect a battery (be ready to pull the battery cable quickly in case of a short circuit) and insure you have fire to the plugs. Fill the fuel bowls of the carb through the vents with a small funnel hose or whatever you can contrive that won't spill it all over the place. If the bowls don't leak and you have spark to the plugs, give it a try.
May have forgotten a few things, so just check everything you can think of that will be affected when/if the engine starts, like making sure it is not in gear and there is fluid in the transmission, etc., etc..
08-17-2012, 02:06 AM
#4 | | Do The Evolution
Welcome. Personally, I would pull it and start the rebuild. Congrats on the project!
08-17-2012, 02:21 AM
#5 | | Registered User
/\ x2 on what Trojan Horse said. Have a fire extinguisher handy. #1 mice may have made nests in places that may catch fire once they get hot, #2 the carb may leak like hell from sitting so long!
08-17-2012, 08:55 AM
#6 | | Registered User
Thanks it's a numbers matching engine the guy put in a lean to barn and water got in on it somehow. I've already taken the hood off because it wouldn't close all the way due to rusty engine I'll give it a try today thnks
08-17-2012, 03:04 PM
#7 | | Senior Member
| Re: Startability Quote:
Originally Posted by FortyBrandon Thanks it's a numbers matching engine the guy put in a lean to barn and water got in on it somehow. I've already taken the hood off because it wouldn't close all the way due to rusty engine I'll give it a try today thnks | Just double check everything and make sure it is oiled good and has fuel without it leaking all over and you will be fine. I have done numerous of these types of start ups over the years and the only real failures were the engines that had gotten water in them and locked up solid. In those cases the engine block is usually ruined and it has to be sleeved or replaced before you can rebuild.
What engine is it, a 302 or 351W?
08-17-2012, 03:11 PM
#8 | | Do The Evolution
It makes you wonder, what kinda of person let's a car like that rot away for 36 years? What's the point of holding on to a car like that if you're not going to maintain it?
08-17-2012, 06:10 PM
#9 | | Registered User
I started up an old 70,s caddie that had been sitting for nearly ten years. It had a 500c.u. in it. A big monster car and engine. All I did was air up the tires, swap out the battery, put some new fuel in it, and primed the carb. I kid you not, it started up within 2 turns of the engine. I took it for a drive and the sob even passed smog. I probably should have oiled things up a bit. But it ran great and I made a few bucks off it. It shocked me how easily it started. Since you are looking to run this engine, I'd take the time to safeguard the internals by lubing it up like they suggested before you turn it over. Good luck.
08-17-2012, 07:22 PM
#10 | | Registered User
IRS a 351 windsor lol I found this car on craigslist and when I called to set up the appointment the same day it was put on craigslist it was sold I was looking on eBay a week later and saw the same car on eBay so I worked a deal out and I picked it up I called the guy who owned it in virginia he told me the whole story it was his high school car and he raced z28 s and said he never lost than he bought a van and put the car n a lean too barn and water got on it. He said he drives a Porsche and a 2006 gt. I guess he was just lazy with it.
08-17-2012, 08:39 PM
#11 | | Senior Member
Originally Posted by primer2tone It makes you wonder, what kinda of person let's a car like that rot away for 36 years? What's the point of holding on to a car like that if you're not going to maintain it? | It happens more often than you might think. You get a car you are partial to, something happens and you cannot fix it up like you want, but you can't bear to part with it....... Quote:
Originally Posted by FortyBrandon IRS a 351 windsor lol I found this car on craigslist and when I called to set up the appointment the same day it was put on craigslist it was sold I was looking on eBay a week later and saw the same car on eBay so I worked a deal out and I picked it up I called the guy who owned it in virginia he told me the whole story it was his high school car and he raced z28 s and said he never lost than he bought a van and put the car n a lean too barn and water got on it. He said he drives a Porsche and a 2006 gt. I guess he was just lazy with it. |
He's pulling your leg a bit unless it has had some performance work done to it. I owned 2 69 Mustangs back in the day and while they ran good stock they didn't run that good. I had to run a tuned 750 DP carb, long tube headers, 2.5" H-pipe exhaust, Crane Fireball cam, and a 3.91 geared traction lock to compete with the Z28's. Smoked a couple of those a Heavy Chevy Chevelle and a hot rod Nova too after the mods though.
08-17-2012, 09:19 PM
#12 | | Registered User
| Quote: |
He's pulling your leg a bit unless it has had some performance work done to it. I owned 2 69 Mustangs back in the day and while they ran good stock they didn't run that good. I had to run a tuned 750 DP carb, long tube headers, 2.5" H-pipe exhaust, Crane Fireball cam, and a 3.91 geared traction lock to compete with the Z28's. Smoked a couple of those a Heavy Chevy Chevelle and a hot rod Nova too after the mods though.  | Well it has duel exhausts when it was a one it has a four barrel Holley instead of 2 he said he put Shelby cams in it but idk I know nothing of these old cars since I drive a 99 cobra and my fiance drives a 04 gt I'm used to the 4.6 modulars than the 650 Holley lol its bad but I've never even heard of Holley until I saw his sticker he had on the window I guess that's what happens if your born into separate generations
08-17-2012, 09:27 PM
#13 | | Senior Member
Originally Posted by FortyBrandon Well it has duel exhausts when it was a one it has a four barrel Holley instead of 2 he said he put Shelby cams in it but idk I know nothing of these old cars since I drive a 99 cobra and my fiance drives a 04 gt I'm used to the 4.6 modulars than the 650 Holley lol its bad but I've never even heard of Holley until I saw his sticker he had on the window I guess that's what happens if your born into separate generations | Yes, that's what happens. I was a teenager when those were still on the road all over the place and could be bought for $500 - $1500 in good running condition.
08-17-2012, 09:36 PM
#14 | | Registered User
| Quote: |
Yes, that's what happens. I was a teenager when those were still on the road all over the place and could be bought for $500 - $1500 in good running condition. | Lol I read a boss 302 could be bought around 4 g and now there like 43g for a 13 boss a 19 yr old can't afford that lol!!
08-17-2012, 10:35 PM
#15 | | Senior Member
Originally Posted by FortyBrandon Lol I read a boss 302 could be bought around 4 g and now there like 43g for a 13 boss a 19 yr old can't afford that lol!! | Yes and sadly 4K back then was almost as unattainable as 43K is now for me too.
