No hazards lights - ideas? - Mustang Evolution
Old 09-22-2012, 11:21 PM   #1
6805stang's Avatar
My 68 Mustang has no emergency flashers, I've looked at the wiring and there is no flasher fuse or a place to put one. What can I do to install them?
6805stang is offline   Reply With Quote
Old 09-23-2012, 09:20 PM   #2
LukeRailey68's Avatar
Are you rewiring your car? Flashers must be standard. Wiring should go to the connection under the steering column of course.
LukeRailey68 is offline   Reply With Quote
Old 09-24-2012, 12:48 PM   #3
6805stang's Avatar
I'm not rewiring the car, not yet at least. Could I splice a connector for the fuse? If so, what wire would I splice to? Is there one wire that controls both blinkers? There is a flasher button on the steering column, so it must've had it before. This car was really done half assed from the guy I bought it from, so every little thing fights me. Thanks for responding, I appreciate any help I get.
Old 09-24-2012, 03:08 PM   #4
Well you might have to wait to rewire the whole car or under the dash, but I believe their is just one wire. See if your turn signal connector (that is under the steering column) is missing a wire. The wire should go from the connector to its own flasher. It is white and red #4 in the diagram of the connector.
Old 09-24-2012, 03:11 PM   #5
I'm sorry but I probably misread. Your just missing a flasher right? I thought you were missing the whole wire. I'm assuming your emergency lights turn on as well.
Old 09-24-2012, 03:11 PM   #6
gc19662007's Avatar
The car should have had flashers and I don't know how bad it has been butchered. I did find the original wiring diagrams for that year Mustang. Hopefully these will help.
ID:	69932   Click image for larger version
gc19662007 is offline   Reply With Quote
Old 09-24-2012, 06:20 PM   #7
BA68 mustang's Avatar
God this sounds way too familiar...I haven't looked into the flashers yet but I'm going to now
BA68 mustang is offline   Reply With Quote
Old 09-24-2012, 08:51 PM   #8
Aggiesrok's Avatar
You can download colo wiring diagrams from Virginia Mustang. You might just be missing the flasher module and the wires are loose or taped together.
Old 09-24-2012, 09:23 PM   #9
6805stang's Avatar
All the lights work except for the flashers. Thanks for all the diagrams!
Old 09-24-2012, 10:56 PM   #10
Aggiesrok's Avatar
Have you replaced the flasher module?
Old 09-27-2012, 02:33 PM   #11
6805stang's Avatar
I haven't replaced the module, where is it? I haven't had a chance to look at the diagrams yet. Work has been crazy.
Old 09-27-2012, 10:13 PM   #12
Aggiesrok's Avatar
It's under the dash on the drivers side. It's either a small metal cylinder a little smaller than shot glass or a metal cube about the same size with 2 wires connected to it.
Old 09-30-2012, 07:19 PM   #13
Tyoung68's Avatar
i Have the same problem but its with the turn signals and the flashers
Lights Out; Any Ideas? Mdavis1024 1979-1995 Mustang GT 18 01-16-2012 04:52 PM
fog lights mystang50 1979-1995 Mustang GT 11 11-30-2011 07:06 PM
tail lights.? mystang50 1979-1995 Mustang GT 5 10-09-2011 01:32 PM
Stay on running lights uh60facilitator Mustang Paint, Appearance & Detailing 0 08-17-2011 12:19 PM
02:51 AM
