66 mustang - trans issues - Mustang Evolution
Old 09-23-2012, 06:14 PM   #1
Question 66 mustang - trans issues
i'm having some trouble with my transmission in my '66. i've already checked the fluid, it seems to be good. however, the car is having trouble changing gears. when i shift from park to reverse, it acts as if its in neutral and just sits.
any ideas on what might be causing this?
Mac14 is offline   Reply With Quote
Old 09-23-2012, 06:24 PM   #2
DaddyO's Avatar
Is the linkage between the transmission and the shifter handle in good shape? Over time parts wear out.
DaddyO is offline   Reply With Quote
Old 09-23-2012, 06:30 PM   #3
re: 66 mustang - trans issues
could be worn out. hadn't thought about checking that out. when i bought the car, the guy that sold it to me said he had gotten it from an elderly woman who let it sit in the garage and that it had all the original parts. probably does need replacing.
Old 09-23-2012, 08:34 PM   #4
Stanglover1966's Avatar
If you have the stock trans then I think its kinda common in them. Mine did that same.
Stanglover1966 is offline   Reply With Quote
Old 09-23-2012, 09:14 PM   #5
LukeRailey68's Avatar
My transmission finally went out on me last week. It's an automatic and it would only grab reverse. I had my car towed to a shop to get fixed and I was told that the clutch was ruined. Should be like brand new when I get it back tomorrow! Research for a good trans shop and you could get it rebuilt for less than $1000.
LukeRailey68 is offline   Reply With Quote
Old 09-23-2012, 10:14 PM   #6
Yep, same with mine. I just did a engine swap with mine. I figured it would avoid future hassle. Hope all works out for you
Old 09-24-2012, 01:44 PM   #7
Thanks for the suggestions! Hopefully I can get this all worked out soon. I need to be able to get to work with this car!
Old 09-27-2012, 09:58 AM   #8
Commercial Member
matcox83's Avatar
Did you get it figured out? My vote was for loss of prime internally. I also have C4 so am curious. Hope it worked out OK.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
VIDEO: 617HP Supercharged Mustang GT Tears Up Our Dyno! AMDanBailer AmericanMuscle 8 02-24-2014 03:19 PM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
mustang vs. camaro secomejia General Car Discussion 58 09-29-2011 02:03 PM
Derby City (Louisville) Mustang Show DerbyCityStang Regional Mustang Discussion 2 08-26-2011 05:41 PM
07:52 PM
