AJE Racing front suspension on 67 mustang - Mustang Evolution
Old 04-11-2008, 09:25 AM   #1
My name is Richard Evans and this is my first post to your fourms. I have a 67 mustang that you'll see in the pictures along with my wife having her 66 coupe and 00Gt. I have a Performance Shop in San Diego called Classic Performance & Repair and our website is CPRstreetmachines.com so if anyone needs so help trying to do there own mods and gets stuck on a project let me know and I'll try to help you out as much as possible through the forums. Hopefully you'll see me here more ofter posting up.
Here is something we are doing at the shop now
We will be installing AJE racing's tubular K-member, A-arm, Coil over kit front suspension on our 1967 turbocharged mustang. We will be able to notch out the shock towers, add rack and pinion, upgrade to cobra disc brakes, have a bolt in K-Member like the new mustangs, adjustable coil over struts and much more room in the engine bay for the existing turbo kit. ;D
pic of the car
pic of the stock engine bay
what it will look like with the AJEracing front suspension:
here is the link to the artical from PHR magazine:
Richard Evans' '67 Ford Mustang - Popular Hot Rodding Magazine
CPRsm is offline   Reply With Quote
Old 04-11-2008, 09:26 AM   #2
Re: AJE Racing front suspension on 67 mustang
pulled off the upper and lower control arms, steering, shocks, struts... and all the other misc crap that isn't needed any longer
Old 04-11-2008, 09:26 AM   #3
one last look before I start cutting it up
I ended up using a sawz-all and plasma cutter to get most of it out, I still need to fine trim up everything use the spot weld remover and the air hammer.
went ahead and made a template out of cardboard and used a paint pen to mark the towers
Old 04-15-2008, 06:08 PM   #4
here are some more pics
the stock upper spring plate holder needs to be removed for the new caster camber plates to able to be installed
using 14 g. sheet of material, made a template and cut out part of the plate using a plasma torch to overlay the tower.
welded the plate from the inside the tower under the fender
picture of the plates welded on
here is what the finished product will look like and the tower smoothed!
next step is steering...
our 67 has a 1 piece steering shaft and box so we had to cut it.
Old 04-15-2008, 06:40 PM   #5
fast64's Avatar
Very cool, how much does that steering setup run?
GO BRAVES
Old 04-17-2008, 02:09 PM   #6
Herbstang's Avatar
Very Nice !!!! gotta tell my buddy about what your doing he has 2 67 stangs
Old 04-21-2008, 11:34 PM   #7
2500-2700 with monual rack or power steering rack
AJEracing.com
Remove the stock crossmember and bolt up the k-member to the frame using the second hole in from the back to line up the k-member. we put in inserts into the frame so the frame doesn't bend when attaching the k-member in.
drill, insert, tack weld or weld.
assembly of the a arms, struts
tighten with a torque wrench to 65lbs and blue lock-tite
the strut retainer needs to be rounded off otherwiseh it will hit the inner side of the coil over and make a nocking noise
the aje kit laid out prior to install
k-member installed
bolted up to the inserts
Old 04-21-2008, 11:35 PM   #8
new caster plates installed
installing the strut and installing the screw in clamp and coil springs
installing the pinto rack along with the clamp for the rack from aje
Since I went with the SN95 spindle assembly I put on the hub from a set of Cobra calipers and slot/ drilled rotors
Old 04-22-2008, 02:50 PM   #9
here are some completed pictures, still need to take some more suspension pictures.
Old 04-22-2008, 03:00 PM   #10
Dang, quite a project and nice work.
Old 04-22-2008, 08:50 PM   #11
rocknbronco's Avatar
Nice.
rocknbronco is offline   Reply With Quote
Old 04-25-2008, 10:02 AM   #12
thanks for following along
Old 04-25-2008, 10:51 AM   #13
Herbstang's Avatar
Very Nice !!!!
Old 04-25-2008, 11:22 AM   #14
afinley11's Avatar
That is one bad *** ride, I like it!
I would one day like a start a 69 stang, but alas I do not have the money to do so now..caught up in two other project right now!
I am jelious, that ride kicks arse!
04 stang (Gone):
Best 1/4: 13.813 @ 104.35 <top MPH 109+..Durn Traction)
310/318 @the wheels Procharged 3.8L
New Baby:
1989 5.0 5spd Great plans for this monster!
afinley11 is offline   Reply With Quote
Old 04-25-2008, 08:43 PM   #15
Yeah its plain sexy.....
Old 04-26-2008, 11:38 AM   #16
Thank you.
www.CPRstreetmachines.com
info@CPRstreetmachines.com
San Diego, Ca
Old 08-10-2014, 07:17 PM   #17
Old Pictures
I am new to this site and would like to retrieve the old photos in this post..is that possible?? Thanks,John
jcortf1 is offline   Reply With Quote
New front suspension today mchaggis50 General Mustang Discussion 5 08-26-2009 01:04 PM
Front Suspension villa029 Pre-2005 V6 Mustang 10 05-11-2009 02:26 PM
Front Suspension Question 00vertstang Pre-2005 V6 Mustang 2 09-29-2006 11:55 AM
02:25 AM
