Front suspension help - Mustang Evolution
Old 10-24-2012, 03:49 PM   #1
Stanglover1966's Avatar
I bought the mustangsplus Grab-A-Trak suspension and along with the lower control arms came 2 thin, ring-like metal objects. I have never seen them before and I need someone to tell me what the are if that is possible. Thanks.
Stanglover1966 is offline   Reply With Quote
Old 10-24-2012, 05:34 PM   #2
Aggiesrok's Avatar
Throw a pic up with some sense of scale, how big are they?
Old 10-24-2012, 08:44 PM   #3
Commercial Member
matcox83's Avatar
Are they like a large washer with an offset hole? Could be an eccentric for camber adjustment. Not mentioned in the instructions?
Old 10-25-2012, 03:43 PM   #4
Sadly to day there are no instructions for them :/ they are about the size of quarter. They look a bit like washers but they look more like a dome with a little bit of the top cut off. I'll get some pictures up when I get back to my house.
Old 10-25-2012, 09:16 PM   #5
mike Franklin's Avatar
I don't see what you're talking about in the drawing.
mike Franklin is offline   Reply With Quote
Old 10-26-2012, 07:03 AM   #6
Commercial Member
matcox83's Avatar
I looked online at the LCA and didn't see it either. I did see the eccentrics in some photos. We're really curious now. Let's have a picture of it
Old 10-26-2012, 03:46 PM   #7
They didn't come with that package. They came with the lower control arms which is a different product.
Old 10-28-2012, 10:19 AM   #8
Without seeing them I would guess that they are used to set the caster/camber and go on the inner control arm connection point.
Old 10-31-2012, 09:28 PM   #9
Here are the pictures of those parts I was talking about. Anyone recognize them?
ID:	74233   Click image for larger version
Old 10-31-2012, 10:25 PM   #10
Those look like the washers that go over the ends of your suspension bushings.
Old 11-01-2012, 04:18 AM   #11
Ahh okay, the stock suspension didn't have them so it confused me.
Old 11-06-2012, 06:19 PM   #12
Tyoung68's Avatar
you probably figured it out by now but those go on your sway bar bushings
Old 11-07-2012, 07:40 AM   #13
I highly doubt that cause they came with the lower control arms and the sway is apart of the grab-a-Trak suspension kit while the lower control arms were a separate product.
Old 11-07-2012, 11:44 AM   #14
Tyoung68's Avatar
They go on the lca where the sway bar bolts to the lca. They sandwhich the control arm and are to stop the busing from getting pulled through ill get you a picture
Old 11-08-2012, 07:26 AM   #15
Alright, kinda hard for me to picture it
06:30 AM
