power brakes???? - Mustang Evolution
Old 04-22-2008, 04:41 AM   #1
stang_gang's Avatar
power brakes????
i have a 68 fastback and i already converted it to front disks using parts off a 79 granada. well my brakes suc even worse now. i want to put power on her but i was told you have to change the brake pedal. the power booster and master clyinder came off the same car. also do i need to change the proportoning valve to a disk brake one?
Mustangs are not anobsession they are a way of LIFE!!!
stang_gang is offline   Reply With Quote
Old 04-25-2008, 09:01 AM   #2
Re: power brakes????
did you use and adjustable push rod that is needed after doing the swap?
also, when putting stock style power brakes on it you do need the stock power pedal. there are other kits out there that don't require the stock style pedal though.
CPRsm is offline   Reply With Quote
Old 04-25-2008, 07:51 PM   #3
rocknbronco's Avatar
X2
rocknbronco is offline   Reply With Quote
Old 04-25-2008, 08:28 PM   #4
stang_gang's Avatar
no just used the disk of the granada, none of the power stuff is on my stang, its still manual but with disk instead of drums. ordered a gt dick brake proportioning valve for it so maybe that will help.
Old 04-26-2008, 10:32 AM   #5
when swapping over you also need to change the master cylinder. Get a master cylinder from a 74-5 maverick with manual front disc brakes. The MC for manual disc brakes has a different bore size in to make the brake work the way there are meant to. And, you also need the proportioning valve. Adjust it to when you stomp on the brakes the back brakes do not lock up first.
Classic Performance & Repair
www.CPRstreetmachines.com
info@CPRstreetmachines.com
San Diego, Ca
Old 04-26-2008, 10:47 AM   #6
stang_gang's Avatar
oh ok thanks for the advice ill give it a try.
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 06:40 PM
Help with Brakes 98StangGT 1996-2004 Mustang GT 3 12-28-2006 01:39 PM
brakes.. Fishers Stang Pre-2005 V6 Mustang 14 01-13-2005 06:32 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
07:37 PM
