1966 Mustang Welding. Which Welder Do You Recommend? - Mustang Evolution
Old 11-09-2012, 12:38 PM   #1
I recently bought a 1966 Mustang project car and I need to replace the rear frame rails, floor panels and body panels. Which welder should I buy that will work for all three projects. I do not want to spend a fortune. Thanks for the help.
KATMAN44 is offline   Reply With Quote
Old 11-09-2012, 04:11 PM   #2
Rm360's Avatar
The Lincoln weld pak 100 is a nice little unit as is the Miller mighty pak, both welders plug into standard wall outlets , which is a plus if you don't have a 220 line , both welders use flux core wire, which is wire that you don't need shielding gas with , personally I would invest in the gas conversion kit with either one, you can buy the Lincoln at menards, Home Depot , lowes etc.... The unit with gas kit is I want to say like $300 , the miller you would have to order and may be a bit higher in price
Old 11-09-2012, 05:10 PM   #3
gc19662007's Avatar
I have a Lincoln electric 3200HD weld pack using .035 flux core wire myself using just the 120vac plugs. I've welded a new roof, quarter panels, floor,trunk floors, subframes to new new floors, taillight panel and rear dash work with no issues. The 66 is a unibody and mostly sheet metal anyway so if you got a decent welder an know how to weld, it shouldn't be an issue. I have yet to weld in the TCI front suspension but knowing the welder as I do, I have no doubt it will go in smoothly.
---------- Post added at 07:07 PM ---------- Previous post was at 07:04 PM ----------
Just do plenty of practice welding with the same thickness of metal before you touch the car. Know how it welds, know how the metal reacts to the welder, know when you get good penetration, know how it looks when you get done welding. Gas is good but not totally needed, just a lot more to clean up when you get done welding.
---------- Post added at 07:08 PM ---------- Previous post was at 07:07 PM ----------
Building a 66 coupe.
---------- Post added at 07:10 PM ---------- Previous post was at 07:08 PM ----------
Also, body panels take forever if you want to get them on without warping the metal. Spot welds are very tedious but worth it in the end. Trust me.
gc19662007 is offline   Reply With Quote
Old 11-09-2012, 05:28 PM   #4
NewMtang's Avatar
Cheaper
Sounds like you don't have much welding experience. Save the money and find someone who does have he experience. So if he or she, screws it up, you can get re-imbursed.
Old 11-10-2012, 05:12 AM   #5
gc19662007's Avatar
It is not difficult to learn sheetmetal welding. Just takes a bit of practice.
Old 11-24-2012, 07:08 PM   #6
08SteedaQ350's Avatar
Don't know if you need this. But I found it on Craigslist. Figured I'd search ME and see if anyone had a project car for the years listed.
08SteedaQ350 is offline   Reply With Quote
1966 mustang
06:19 AM
