In need of assistance - Mustang Evolution
Old 11-19-2012, 05:43 PM   #1
Ey guys i need some help. Today I was going to try out my car and when I turned it on this black liquid sprayed out my tail pipes. My oil pressure is way low even though oil was just added and there was a lot of white smoke last time I drove it. What could this all be? Thanks in advance.
My68mustang is offline   Reply With Quote
Old 11-19-2012, 05:44 PM   #2
tc x 4's Avatar
No worry, just condensation in the pipes.
Old 11-19-2012, 06:56 PM   #3
Aggiesrok's Avatar
Could a head gasket. Check your oil again and make sure not milky brown. Could be condensate mixing with carbon build up. But the low oil pressure is worrisome.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 11-19-2012, 07:28 PM   #4
Yeah I read it could be condensation if it happened on cold mornings then went away, but this was during warm weather at 3:00 in the afternoon and constant until I got home. We checked compression not to long ago and it was good. Could it be the intake gasket?
Old 11-20-2012, 07:38 AM   #5
Commercial Member
matcox83's Avatar
What is the consistency of the liquid? If it is like water, it is probably condensation with carbon build up mixed in. Oily would be worse. May not be related to your other problem tho.
Old 11-20-2012, 08:22 AM   #6
garbill2003's Avatar
Sounds like a problem to me make rings how many miles is on it?
garbill2003 is offline   Reply With Quote
Old 11-20-2012, 09:17 AM   #7
The Guy I got the engine from said about 145000 original miles, but he had replaced the pistons not long ago. I don't know exactly how the liquid was, it was dry by the time I noticed it.
Old 11-20-2012, 09:19 AM   #8
Sounds like carbon build up
Old 11-20-2012, 10:13 AM   #9
Yeah? I hope! The intake was just replaced. Could it be the intake gasket is leaking coolant and that's what the white smoke is about? I hope it is just carbon mixture.
Old 11-20-2012, 10:18 AM   #10
tc x 4's Avatar
I think you just figured it out. As already stated, check your oil, it'll look milky if It's leaking. Could also be a cracked head.
Old 11-20-2012, 10:24 AM   #11
Ahhhh.... Worse case scenario is something is broken!
Old 11-20-2012, 10:33 AM   #12
tc x 4's Avatar
As long as you haven't overheated it, I wouldn't sweat it. But you need to figure it out before you do overheat it, else its gona get expensive fast .
Old 11-20-2012, 12:36 PM   #13
Ok just got home and checked my oil and it's really low, just below add mark. Also my coolant reservoir is totally dry.
Old 11-20-2012, 12:52 PM   #14
You have a head gasket or manifold leak do you smell the antifreeze?
Old 11-20-2012, 01:00 PM   #15
Well I didn't turn it on so I didn't really smell anything. If its the manifold I need to buy a new gasket right? I can't reuse it?
Old 11-20-2012, 01:05 PM   #16
No but i would say you have a head gasket leak any puddles onset it?
Old 11-20-2012, 01:17 PM   #17
Actually i did notice a small one right under the oil pan.
Old 11-20-2012, 01:18 PM   #18
Rear main seal back by the transmission?
Old 11-20-2012, 01:33 PM   #19
Umm wait are you asking if that's where it's located?
Old 11-20-2012, 01:35 PM   #20
Correct
Old 11-20-2012, 01:41 PM   #21
To be honest I couldn't say for sure. It's an 87 5.0 and t5 tranny.
Old 11-20-2012, 02:17 PM   #22
Add motor oil antifreeze to where it should be drive it then check to see how much it changes.
Old 11-20-2012, 02:20 PM   #23
tc x 4's Avatar
Your gona need a new gasket for sure. The oil concerns me, make sure there is no cracks in the heads when you put it back together. Trojan horse & dreamstang are pretty much experts on the fox, so if you have problems pm one of them, they're very helpful.
Old 11-20-2012, 02:22 PM   #24
Yeah that's a good idea. I'll do that today or tomorrow. Depending on how it goes I might take it to the mechanic on Friday.
Old 11-20-2012, 02:50 PM   #25
Aggiesrok's Avatar
It's ok if your reservoir is dry, did you open the radiator cap (of course with the engine absolutely cold) and check to see if your low on coolant in the radiator. You might want to go ahead and change your oil, just to see what it looks like. If its not dark brown or black and motor oil thick, but milky, you've got a head gasket issue.
Even if the oil level is just touching the dipstick, it probably should not have a low pressure reading (maybe a little less than normal but not low).
Old 11-20-2012, 02:53 PM   #26
Yeah I checked the radiator and was pretty full. The oil is brown but not thick and the oil pressure was marked as low as it goes.
Old 11-20-2012, 02:59 PM   #27
Aggiesrok's Avatar
Sounds like you're definitely getting some coolant into the oil.
Old 11-20-2012, 03:04 PM   #28
Yeah now I just have to find out from where.
Old 11-20-2012, 03:33 PM   #29
Aggiesrok's Avatar
It's most likely a head gasket and hopefully not a crack.
Old 11-20-2012, 04:17 PM   #30
Hopefully. If its a crack the engine is jacked, there goes my 5.0.
Old 11-22-2012, 03:39 PM   #31
Ok I filled the oil today and drove it to the gas station and the oil pressure gauge is still marking as low as possible. And when I turned it off my left tailpipe was smoking (don't know if that's normal). Does this help diagnose the problem any better?
Old 11-22-2012, 05:25 PM   #32
BigpapaDean's Avatar
Hey bud, not to make you freak but I found the same issue with my 67. I did have to rebuild my engine. Something about a ring and cylinder wall being no good. It was the same thing, light coloured smoke out of my left tail pipe. If the smoke is always there, then it has to be internal and you will end up having to rebuild the block....or find another 5.0. Good luck.
BigpapaDean is offline   Reply With Quote
Old 11-22-2012, 06:16 PM   #33
To late I'm freaked! This bites, ima take it to the mechanic this Saturday and pray the whole way there. I don't think I will rebuild the block if it's jacked. I'll just instal the original 289, just buy the right flywheel. Damn it.
Old 11-23-2012, 07:49 AM   #34
Hey it's not the end of the world. I surpassed my budget so much I thought I'd have to sell my mustang....but, she's still here. This is the reality we chose when we buy these older vehicles. Don't worry about it.
Old 11-23-2012, 06:00 PM   #35
Jaja well when your right your right. I love my car and I'll do what i can to make it work.
02:25 PM
