Tranny problem - Mustang Evolution
Old 11-27-2012, 09:58 PM   #1
Tyoung68's Avatar
Tranny problem
It wont shift out of first and its full i can manually shift it from 1 to 2 with the shifter. So why wont it shift in drive??
Old 11-28-2012, 06:30 AM   #2
Aggiesrok's Avatar
Have you checked the fluid level? It may need changing along with the filter.
Old 11-28-2012, 07:26 AM   #3
Commercial Member
matcox83's Avatar
Check the vacuum modulator. Look for fluid when you disconnect the hose. Won't shift right if the modulator is bad.
Old 11-29-2012, 08:12 PM   #4
Tyoung68's Avatar
Could it matter if my bands arent adjusted right ?
Old 11-30-2012, 06:56 AM   #5
Commercial Member
matcox83's Avatar
My opinion is no. The bands don't care if you shift auto or manual. They must hold for the gear to work. Check the easy stuff first. Bands don't get out of adjustment overnight. A vacuum modulator can fail while you are driving.
Old 11-30-2012, 11:10 AM   #6
Tyoung68's Avatar
Yeah illcheck that as soon as it stops pissing rain haha
Old 11-30-2012, 05:04 PM   #7
Tyoung68's Avatar
How do k know if its bad?
Old 11-30-2012, 06:30 PM   #8
Commercial Member
matcox83's Avatar
If the diaphragm breaks trans fluid will be visible. That is the most frequent failure mode. Check to make sure the vacuum hose to it is good. Shouldn't cost much to replace. If it is original it won't hurt to replace anyway.
Old 11-30-2012, 07:56 PM   #9
Tyoung68's Avatar
Well its fine by what i can tell when i check the fluid whats it suppose to be in like park or neutral? I thought it was suppose to be in neutral but on the dipstick says park?
Old 11-30-2012, 08:19 PM   #10
Commercial Member
matcox83's Avatar
Park and neutral are the same to the trans
Old 11-30-2012, 08:37 PM   #11
Tyoung68's Avatar
Oh... Ha well hmm then anyother ideas? I have a shift kit in my car too
Old 11-30-2012, 08:43 PM   #12
fomoco4life's Avatar
You sure that diaphragm is good bro?I would replace it like $10 or something. Check that vacuum line thats coming off it maybe vacuum leak
Old 11-30-2012, 08:45 PM   #13
Tyoung68's Avatar
I put a vacuum on the diaphragm and it held what happens if theres to much fluid?
Old 12-02-2012, 12:51 PM   #14
I've heard your seals blow out quicker if you have too much fluid in there but if you think you do just crack a couple of them panbolts let some out. However too much fluid should not affect your shifting
06:06 PM
