'69 fastback frame rail/torque box question--with pics - Mustang Evolution
Old 05-11-2008, 09:58 PM   #1
I have a '69 fastback that has been wrecked and shoddily repaired in the past...and to add insult to injury, the LF frame rail under the tower and both shock towers are rusty. On top of all that both front aprons and core supprt have been cut off and the strut rod housings are mangled/bent.
Needless to say, I need pretty much everything from the firewall forward. The only salvageable part is the RF framerail...and it may be tweaked since the framerail distance varies +/- 8mm between the end of the rail and the shock tower.
Here is where my question comes in:
I just bought a complete Mustang front clip with big block shock towers. I am trying to decide the best way to swap it in and keep everything lined up within specifications.
My thought is to separate the frame rails/shock towers/aprons as an assy from the firewall and torque boxes on both the clip and the car while leaving the seat support rails in place as a guide as to where everything should line-up when going back together. I figure if I start with the whole car level and the front frame rails level--that I should be able to slide the new rails/clip into the floor pan supports/rails until:
the aprons mesh the firewall perfectly
the frame rails slide to the proper depth in the floor supports
and the front frame rails are level like the originals were
Does this sound like it would work?
How hard is it to separate the frame rails from the torque boxes without hurting the rails or torques boxes? (both the car and clip have VERY solid torque boxes) Should I leave the torqueboxes attached to the replacement frame rails and swap them in also?
ID:	19186   Click image for larger version
ID:	19188   Click image for larger version
helrazr70 is offline   Reply With Quote
Old 06-28-2008, 12:03 AM   #2
Re: '69 fastback frame rail/torque box question--with pics
its not easy...
some insight on the job.
floor board replacement 69 fastback
Classic Performance & Repair
www.CPRstreetmachines.com
info@CPRstreetmachines.com
San Diego, Ca
CPRsm is offline   Reply With Quote
Old 07-01-2008, 07:53 PM   #3
fast64's Avatar
would it be easier to replace the entire front clip rather than trying to create a seem between the two?
GO BRAVES
67 fastback owner - frame up here we go twisted_pretzel Classic Mustangs 1 02-01-2008 08:44 PM
68 Mustang front frame rail specs. brianb25 Classic Mustangs 1 09-19-2007 12:59 PM
07:52 AM
