Any ideas - Mustang Evolution
Old 01-02-2013, 08:00 PM   #1
iStang65's Avatar
Region: Alaska
Any ideas
Trying to remove the hardware in the suspension area and some nuts and bolts are stuck solid. I've sprayed some PB blaster and it loosened it up a small bit but still no luck on the actual removal of the hardware
iStang65 is offline   Reply With Quote
Old 01-02-2013, 08:03 PM   #2
sally2002's Avatar
Heat it up and then try to loosen it
sally2002 is offline   Reply With Quote
Old 01-02-2013, 08:04 PM   #3
iStang65's Avatar
Region: Alaska
Heat it up?
Old 01-02-2013, 08:06 PM   #4
v8pony's Avatar
Heat it up?
Torch
2002 5spd GT
Feb 2013 Mustang of the Month
Old 01-02-2013, 08:06 PM   #5
sally2002's Avatar
Heat it up?
Are you talking like nuts and bolts
Old 01-02-2013, 08:10 PM   #6
iStang65's Avatar
Region: Alaska
Yes
---------- Post added at 06:10 PM ---------- Previous post was at 06:07 PM ----------
Originally Posted by NJstanger View Post
Torch
Just started learning how to work on cars. Not sure how to exactly heat up the nuts and bolts with a torch
Old 01-02-2013, 08:14 PM   #7
sally2002's Avatar
Just take a simple hand held torch and heat up the nut you are wanting to remove and work it back and forth
Old 01-02-2013, 08:16 PM   #8
iStang65's Avatar
Region: Alaska
How much do torch's run? And it won't but the sheet metal surrounding the nut?
Old 01-02-2013, 08:24 PM   #9
v8pony's Avatar
Get a handheld one for under 30$ bucks prob at any hardware store , Home Depot , lowes, etc... You'll be fine just heat the suckers up they should budge
2002 5spd GT
Old 01-02-2013, 08:25 PM   #10
sally2002's Avatar
Something like this is all you really need and your local hardware store or Walmart will have it just not really sure about price
Old 01-02-2013, 08:25 PM   #11
iStang65's Avatar
Region: Alaska
Thanks for everyone's help. If it wasn't for this forum, my car would just be sitting here with me not knowing what to do
Old 01-02-2013, 08:27 PM   #12
v8pony's Avatar
No problem bro
---------- Post added at 10:27 PM ---------- Previous post was at 10:26 PM ----------
Exactly..pretty sure I've seen them at Walmart for cheap around 30$
2002 5spd GT
Old 01-02-2013, 08:27 PM   #13
sally2002's Avatar
No problem glad to help
Old 01-02-2013, 11:28 PM   #14
Aggiesrok's Avatar
Just be careful with the torch around fuel lines and rubber lines, bushings, etc. the torch can be found in the plumbing dept. get one with a built in igniter they're easier to mess with.
Old 01-03-2013, 12:11 AM   #15
iStang65's Avatar
Region: Alaska
Ok thanks for the heads up
Old 01-03-2013, 02:12 AM   #16
Venomouz831's Avatar
Or air tools
)02 Gt, Founder of WE2G
Old 01-03-2013, 02:17 AM   #17
iStang65's Avatar
Region: Alaska
Originally Posted by Venomouz831 View Post
Or air tools
I was also thinking about that but wasn't sure on what size air compressor I would need for use of any air tools
Old 01-03-2013, 02:22 AM   #18
Don't get a pancake style one. Get a good one with at least 20 gallon or at least 5hp
Old 01-03-2013, 09:50 AM   #19
Aggiesrok's Avatar
+1
Most of the automotive type tools require 80-90 psi to function and at that rate you need some tank storage or else your compressor will be running every 2 minutes. Get the biggest you can afford and then get the next size. The little ones are only good for filling tires and airbrushing and finish nail guns.
Old 01-03-2013, 12:22 PM   #20
iStang65's Avatar
Region: Alaska
Would something like this work?
Old 01-03-2013, 12:44 PM   #21
That's a decent size one. You can find them cheaper on Craig's
Old 01-03-2013, 12:44 PM   #22
iStang65's Avatar
Region: Alaska
Ok cool. And what all do I need to buy to have a basic starter set of air tools
Old 01-03-2013, 12:49 PM   #23
This is the tool set I got from craftsman on Black Friday. Great starter tool set. Look on sears or any hardware store that might sell these kits.
Old 01-03-2013, 12:50 PM   #24
iStang65's Avatar
Region: Alaska
Cool, thanks for the help
Old 01-03-2013, 12:51 PM   #25
No prob
Old 01-03-2013, 06:14 PM   #26
Aggiesrok's Avatar
You need more HP. 1.5 isn't much. The food news is air tools are a lit cheaper than electric. Air ratchet , sander and impact are a good start.
Old 01-03-2013, 06:17 PM   #27
iStang65's Avatar
Region: Alaska
What about this one? Saw it on sears website but it doesn't say how many HP
Old 01-04-2013, 04:04 AM   #28
Mlarv5's Avatar
What you are looking for is the SCFM at 90psi the higher the better. This is the measure of how much airflow it can supply. If you are not using sanders paint sprayers or grinders then most 20 gallon tanks will do because impact wrenches only use short blast of air.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 01-04-2013, 05:08 AM   #29
iStang65's Avatar
Region: Alaska
What about the HP everyone seems to tell me to get it around 5hp. A lot of these compressors I'm seeing at sears lowes etc have the 20 gallon capacity but are either 1.5hp or 2 if lucky
Old 01-04-2013, 05:13 AM   #30
Mlarv5's Avatar
HP is not a good measure as far as I am concerned until you get up to the two stage big compressors. I had a 1HP 20 gallon tank compressor for many years and it would run an impact driver or socket wrench all day long with out cycling much. The SCFM and the air pressure do the work the motor only runs the pump to fill the tank. To run an impact wrench set it at 90psi and forget it.
Old 01-04-2013, 05:21 AM   #31
iStang65's Avatar
Region: Alaska
Thanks for the insight. Makes it a lot easier pickin up a compressor now instead of searching for one with 5hp that's usually priced around a grand
Old 01-04-2013, 09:14 AM   #32
Aggiesrok's Avatar
Here is the one that I have and it works great, I thought it had more HP, but it runs everything fine.
File Type: pdf craftsman-33-gallon-horizontal-portable-ai.pdf (91.8 KB, 142 views)
Old 01-04-2013, 12:31 PM   #33
Bravebowhunter's Avatar
I bought a 25 gallon with a oil less motor and it runs my air tools just fine found it on Craig's for like 75-100 bucks don't remember what I paid for it but yeah if you hear up the nut it will break it loose make sure you don't heat up the bolt just the nut you can get a hand torch at advance for 30 bucks does me perfectly
Bravebowhunter is offline   Reply With Quote
Old 01-04-2013, 03:21 PM   #34
iStang65's Avatar
Region: Alaska
There's no photo
Old 01-04-2013, 04:11 PM   #35
Aggiesrok's Avatar
It works on computer but not my phone. I'll try again.
08:14 AM
