Where is the drain plug on the gas tank of 1976 mustang? - Mustang Evolution
Old 08-18-2009, 05:45 PM   #1
we have looked and can not find it
maxfield is offline   Reply With Quote
Old 08-18-2009, 05:47 PM   #2
There may not be one. Most cars after the late 60s have none. So the only way to drain is to siphon it out or remove with the fuel in it. If you dont see it on the bottom you dont have one...............UJN
birtingr is offline   Reply With Quote
Old 08-18-2009, 06:41 PM   #3
Dewalt cordless and a 1/2 in drill bit and you will have one.
edoardo is offline   Reply With Quote
Old 08-18-2009, 06:52 PM   #4
There is none
abiram is offline   Reply With Quote
Old 08-18-2009, 07:38 PM   #5
No drain plug - you will have to siphon the gas or get it pumped out (some shops have the equipment to safely pump and store the gas). Or just block the tank securely, undo the straps and drop it down with a jack.
kieron is offline   Reply With Quote
Old 08-18-2009, 08:35 PM   #6
Production cars do not have drain plugs on them.
erland is offline   Reply With Quote
Old 08-18-2009, 09:08 PM   #7
If you can't find it, it must not have one, so you have to drop the tank to clean it out..
brydger is offline   Reply With Quote
Old 08-18-2009, 09:50 PM   #8
there ain't one!! you will have to remove the tank and go from there.
terrel is offline   Reply With Quote
1976 mustang
01:22 PM
