How do the climate control levers work on a 1965 ford mustang? - Mustang Evolution
Old 08-18-2009, 08:45 PM   #1
I understand the fan speed lever which is left to right, there are 3 other levers which go up and down. one is marked heat,is heat at top or bottom, 2nd lever says temp, is cooler at top or bottom, 3rd lever is marked off, what is it for and is off at top or bottom.
meturato is offline   Reply With Quote
Old 08-18-2009, 09:28 PM   #2
pull the three levers down and the fan switch to the right for full heat and defrost.. .
Left is air for heater, down for on...Center is temp, up for cold, right is defrost, down for on.
There is also a knob under the dash for fresh air for driver, and on passenger side, open heater door for fresh air for passenger..
you can find this info in the owners manual and copies of it on ebay..
boothe is offline   Reply With Quote
12:22 PM
