Can you fit a 91 ford engine in to a 1967 ford? - Mustang Evolution
Old 08-19-2009, 08:45 PM   #1
1967 mustang 289 eng.
1990 lincoln 5.0?
want to make it fuel injection
pueblo70 is offline   Reply With Quote
Old 08-19-2009, 09:14 PM   #2
sure but you have to use all the computer stuff and wiring from the lincoln.
imported_dallas is offline   Reply With Quote
Old 08-19-2009, 09:20 PM   #3
You could. However, check yearone.com and see if they have an EFI kit for a 289, that will be cheaper than swaping the motor. If it is a 302 block then you shouldnt have a problem with it going into the car.
Keep in mind that your going to have to do a lot more to make it EFI than just change the motor.
moreley is offline   Reply With Quote
Old 08-19-2009, 10:19 PM   #4
Updated swaps like this are almost common any more. You will need the computer brain box and associated wiring for the 5.0 but yes, it is done all the time.
fuller is offline   Reply With Quote
Old 08-19-2009, 11:15 PM   #5
Yes it will bolt up quit nice is that the HO motor out of a type 7
cuarto is offline   Reply With Quote
11:55 PM
