I recently purchased a 65 mustang. need help? - Mustang Evolution
Old 08-20-2009, 01:45 PM   #1
I bought a 1965 Ford Mustang I dont know to much about the and i had a few questions i hope i can get answered.
Their is a live wire in the car that drains out the battery when the car is off? having trouble finding it...
It leaks oil from the engine and transmission will this be easy to fix??
The muffler shoots out small explosions..can this be easy to fx???
thanks if you at least answer one..
charly is offline   Reply With Quote
Old 08-20-2009, 01:51 PM   #2
connect a amp meter to Battery look at drain
u can pull fuse 1 by 1 out see if it drop
also try to disconnect alt cable and must have external regulator too
those have fusible link short in any one of those can drain bat
oil leak oil pan rusted ,rear and front crank seal ,valve cover
may have small explosions no muffler
it a start cant tell you the problem but help to find it i hope
what engine is in there ??
trystan is offline   Reply With Quote
Old 08-20-2009, 02:38 PM   #3
Simple checks include checking the glove box light (if equipped) to make sure it's turning off and disconnecting any aftermarket accessories the prior owner may have installed.
After wards, if you still have a draw, you can usually pin point the cause by removing the fuses one at a time with the negative terminal disconnected and a test light across the bat terminal to the cable (be sure to close all of the doors when checking the test light).
A draw will lite the test light - when the draw is eliminated, the light will be extremely dim or out.
arrin is offline   Reply With Quote
Old 08-20-2009, 03:30 PM   #4
Good thing about those old mustangs is if your oil pan is the one that's leaking you do not have to pull the motor just to take the pan off.So that's basically easy.as for the transmission.it could be just the pan for it as well.Easy fix.now for the backfire.Could be a valve that is stuck of even a timing chain that has jumped.
Might be too advanced.Easy fix.just remember when your car backfired im sure you blew a power valve in your carburetor.
Those carbs can basically be rebuilt while it sits on the car.
Those old mustangs are easy to work on.My dad had plenty of them when i was growing up.So I am very familiar with them.
stanhop is offline   Reply With Quote
Old 08-20-2009, 04:05 PM   #5
i have a 1967 mustang. !!!
well if its shooting out explosions of the exshaust you shouldnt even turn it on. you should just take it to a mechanic and get it fixed. your timing chain is probally not right. and if so you can blow out your engine and the car wont be worth anything anymore.
and i dont think the leaks will be too hard to fix. some times you can just buy a chemical that will stop leaks. i blew a gasket on my headers of my truck and i just fixed it with a liquid.
sydeek is offline   Reply With Quote
01:48 AM
