How do i do a burnout? - Mustang Evolution
Old 08-20-2009, 02:30 PM   #1
I just got a 1973 Mustang Fastback with a 351 ci two barrel and I'd like to know how to do a burnout in one.
sidney16 is offline   Reply With Quote
Old 08-20-2009, 02:46 PM   #2
HOLD BRAKES< PRESS GAS PEDAL!!
NOW IF THAT OLD ENGINE DON"T DO IT<TRY PUTTING WATER UNDER PASSEGER REAR TIRE..
if that does not work,GO GET A CHEVY!!!
"BRILLIANT"!!!!
culloden is offline   Reply With Quote
Old 08-20-2009, 03:08 PM   #3
idealy:install a line-lock for the rear brakes. hold down the brake and hit the gas. (oil under the tire will help is spin better and smoke more.
about a line-lock: a line-lock is a simple device the releases the pressure on the rear brakes allowing them to freely move. You can do a burnout without one but you will be fighting the friction of your rear breaks.
azuriah is offline   Reply With Quote
Old 08-20-2009, 03:25 PM   #4
Why waste the unrenewable gasoline, burn up your tires to cause air pollution not to mention the exhaust pollution from your stupidity, and wear out your engine and powertrain??????
<blink> <blink>
Why can&#039;t you do something that is not destructive? That is called "growing up"!
makis is offline   Reply With Quote
Old 08-20-2009, 03:52 PM   #5
Don&#039;t do it. it is illegal, wastage of gas, possible damage, need new tires....in conclusion, you will lose.
nyle is offline   Reply With Quote
Old 08-20-2009, 04:30 PM   #6
put in first. hold brake with left foot. give gas with right, when the tires starts burning go up to 2nd. after you burn off all the tread, get new tires.
maxfield is offline   Reply With Quote
» Members Mustangs
Konata
Vivix
Grabber
Slo50
Add your Mustang
08:40 PM
