1965 Mustang fuel problem, I think.? - Mustang Evolution
Old 08-20-2009, 02:45 PM   #1
I try to start my mustang and it just turns over never actually starting or running, just continuous turn over. Plenty of fuel in the car, I thought possible vapor lock, to no avail. Fuel pump?, fuel filter?. Inline 6 cylinder.
I can pump the hell out of it, and no luck.Any help, is much appreciated.
kevyn99 is offline   Reply With Quote
Old 08-20-2009, 03:42 PM   #2
being a 65 Mustang it does have points,unless it has been changed to electronic...do you have spark?
micheal is offline   Reply With Quote
Old 08-20-2009, 04:17 PM   #3
careful not to flood it or over heat the starter
try starting for no more than 5-8 sec intervals
use starting fluid, its in a spray can at the auto store 4 dollars
Are you getting spark buy a tester 5 dollars, auto store
good luck, nice car
napayshni is offline   Reply With Quote
Old 08-20-2009, 04:42 PM   #4
Fuel only- check cap, rotor, plugs and wires
Spark only- check fuel filter, fuel pump
Check your timing if you have fuel and spark at the motor. Engine may be out of time.
macdaibhidh is offline   Reply With Quote
1965 mustang
01:27 PM
