My car will start but why doesnt it want to go? - Mustang Evolution
Old 08-20-2009, 04:15 PM   #1
i have an automatic 1967 mustang that will start but it wont go. when i change it into any gear it wont go. it doesn't move on parking which its obius. but when i put it in drive, reverse, or any other gear it wont go only if you push it but it will feel like in neutral. none of the changing gear's wires that make it change gears are broken or ripped. so what is wrong.
roselyn is offline   Reply With Quote
Old 08-20-2009, 04:37 PM   #2
Most automatic transmissions from the '60s were pretty straightforward. If the fluid level and condition are good and the shift linkage is still working right, there isn't much outside the transmission to go wrong. The kickdown linkage only affects upshifting and downshifting.
agni is offline   Reply With Quote
Old 08-20-2009, 05:25 PM   #3
wu
transmission fluid full ? the servo may be stuck(internal part).if it is a standard then you have a clutch problem.
wu is offline   Reply With Quote
Old 08-20-2009, 05:39 PM   #4
gil
may be it has no destination..?
gil is offline   Reply With Quote
Old 08-20-2009, 05:52 PM   #5
check your transmission that's probably it.
wendell is offline   Reply With Quote
Old 08-20-2009, 06:03 PM   #6
sounds like your transmission is blown
beverley86 is offline   Reply With Quote
Old 08-20-2009, 06:33 PM   #7
The scroungerssrantt working and lacking of pressure makes it impossible to shift. you need to rebuild that puppy,
sein is offline   Reply With Quote
Old 08-20-2009, 06:58 PM   #8
Sounds like low transmission fluid level. Have you checked your transmission fluid? Any automatic transmission vehicle won't move if it doesn't have the right amount transmission fluid. If it turns out there's plenty of fluid then it could be the shifter is off set or the transmission is bad. Good Luck
huntington is offline   Reply With Quote
Old 08-20-2009, 07:42 PM   #9
I had the same problem, this past monday my transmission blew, and my car wouldn't move either, it wouldn't let me change to park or drive from reverse...it would start though.
columbanus is offline   Reply With Quote
Old 08-20-2009, 08:06 PM   #10
Come on ,you say 1967 Mustang.
Oh God 52 years old.Model
You should get the transmission oil checked or even top up if required.If the transmission is fine.
Congratulating you and Wishing you good luck for keeping such an car in operative condition.
bourke is offline   Reply With Quote
04:44 AM
