How do I check to see if my alternator, AC condensor and power steering pump are working good? - Mustang Evolution
Old 08-20-2009, 08:00 PM   #1
Okay I am rebuilding a 1965 Mustang, I pulled the alternatore, ac condensor and power steering pump off, but how do i actually check them to make sure they work, the car has been sitting since 1985, and cranking the engine up and checking it that will not work, any ideas? Also how hard is it to rebuild these items if they are bad?
fitzsimons85 is offline   Reply With Quote
Old 08-20-2009, 08:43 PM   #2
sometimes easier and cheaper just to replace. the a/c compressor that you took off will be have to be refilled with r12 (which is pricey as hell) or retrofitted with r134a (which is also pricey as hell), the p/s pump, well just run it and see if it works and if it leaks, and the alternator you can take to just about any autoparts store and they can check it for free.
dalen is offline   Reply With Quote
Old 08-20-2009, 08:58 PM   #3
You can take the Alternater to a parts store and have it tested , as for the other 2 , you cant the condensor needs to be inline with the system to check for operation and leaks , as with the power steering .
imported_darrell is offline   Reply With Quote
Old 08-20-2009, 09:38 PM   #4
You can't.
dooley28 is offline   Reply With Quote
10:08 PM
