Need to know how climate controls work on 1965 ford mustang? - Mustang Evolution
Old 08-21-2009, 01:15 AM   #1
Roll down the windows with the crank handles in the doors, if the air coming in isn't cool enough, push down harder on the loud pedal.You may need a long stretch of road to get the air coming in cool enough...but thats the fun part!
dunmore is offline   Reply With Quote
Old 08-21-2009, 01:49 AM   #2
Are you sure it even has AC? Big box under the dash with vents ! Red is hot blue is cold , fan speeds are self explanatory, there was no ' climate control ' in those days . Pick a setting and pick a fan speed . Otherwise you have a simple Mustang with heater contols , same thing red = hot blue=cold and no AC
bagwunagijik is offline   Reply With Quote
Old 08-21-2009, 02:45 AM   #3
pull the three levers down and the fan switch to the right for full heat and defrost.. if it is equipted with ac, turn the unit on..
you can find this info in the owners manual and copies of it on ebay..
corley is offline   Reply With Quote
Old 08-21-2009, 02:56 AM   #4
Select mode, like heat defrost, etc. Then select temp setting and turn on the fan. I do not remember a 65 having ac, but if it does, I don't know how it operates.
codi is offline   Reply With Quote
Old 08-21-2009, 03:23 AM   #5
Not sure what your asking but mechanical levers/cables control just about everything. I can't remember if vacuum pods were used or not.
gail is offline   Reply With Quote
Old 08-21-2009, 04:10 AM   #6
Exactly what equipment does your Mustang have?
Heater or none (heater delete was an option then, btw)
Air conditioning?
talmadge80 is offline   Reply With Quote
Old 08-21-2009, 04:26 AM   #7
its all mechanical with cables opening and closing path to heater core, or to different locations like defrost heat vent
comhghan is offline   Reply With Quote
Old 08-21-2009, 05:08 AM   #8
roll down the windows with the crank handle, ahahah
hurste is offline   Reply With Quote
04:23 PM
