I have a high performance Mustang and my starter doesn't work, any suggestions? - Mustang Evolution
Old 08-22-2009, 02:00 PM   #1
I have '66 Mustang V8, high performance 289. I have Long Heddman headers, and a C4 transmission. I have tried the original starter, a new OEM starter, and a gear reduction high torque starter and none of them have worked. When I turn the car to start, the starter just "clicks". I know it's not the neutral safety switch, since it not only happened when the car was on Park, but also on Neutral. I checked the battery and it was charged. The alternator and ignition switch have all passed inspection. Any suggestions?
breandan is offline   Reply With Quote
Old 08-22-2009, 02:48 PM   #2
check your starter solenoid. Thats usually what is wrong when all you hear is the clicking sound.
imported_dallas is offline   Reply With Quote
Old 08-22-2009, 03:02 PM   #3
Did You try dirict wiring to the starter? (Jumping it). Have you tryed to Jump Start the car?
You could have a bad selonid, and you are not getting enough voltage to the starter, (Jump the selonid) You could have the starter jambed aganist the fly wheel causing it to bind (on some models you have to shim the starter away from the flywheel).
derrik is offline   Reply With Quote
Old 08-22-2009, 03:29 PM   #4
You have a bad starter solenoid. An easy fix for your motor. Located on the fender well right behind the battery if it's still in the stock location. The hotwire from the battery hooks directly to it. Been awhile since I bought one but the last one I bought was for a '66 Fairlane with a 302 and it was about $10.00. Same part.
bourke is offline   Reply With Quote
12:48 AM
